Home » Archived » BIRT » Insert file into BIRT report(Insert file into BIRT report)
Insert file into BIRT report [message #870847] Wed, 09 May 2012 17:34 Go to next message
Hi everybody
I'm wondering if there's a way to insert a file into the report and then export it??
Like Excel's functionality 'Insert > Object > Create a file'
Attached an image to clarify
Thanks a lot!! Very Happy
  • Attachment: example.jpg
    (Size: 67.44KB, Downloaded 294 times)
Re: Insert file into BIRT report [message #871052 is a reply to message #870847] Thu, 10 May 2012 12:35 Go to previous messageGo to next message
BIRT supports Java object types but what would you want the export to do?
Jason
On 5/9/2012 5:34 PM, Leticia Simental wrote:
> Hi everybody
> Like Excel's functionality 'Insert> Object> Create a file'
> Thanks a lot!! :d
Re: Insert file into BIRT report [message #871065 is a reply to message #871052] Thu, 10 May 2012 13:28 Go to previous messageGo to next message
Well, i expecting an Excel file with some other files inserted in the file (into cells)
Attached an example
Thanks Jason
  • Attachment: test.xls
    (Size: 12.50KB, Downloaded 259 times)
Re: Insert file into BIRT report [message #871084 is a reply to message #871065] Thu, 10 May 2012 14:07 Go to previous messageGo to next message
Understood. Currently the xls emitter does not support this.
Jason
> Attached an example
> Thanks Jason
Re: Insert file into BIRT report [message #871085 is a reply to message #871084] Thu, 10 May 2012 14:24 Go to previous messageGo to next message
Oooh what a shame! Sad
Thanks you very much for your quick answer Jason!
Regards!!
Re: Insert file into BIRT report [message #871092 is a reply to message #871085] Thu, 10 May 2012 15:38 Go to previous messageGo to next message
This feature could be implemented with the emitter framework extension
and possibly a new report item extension.
Jason
On 5/10/2012 2:24 PM, Leticia Simental wrote:
> Oooh what a shame! :(
> Regards!!
Re: Insert file into BIRT report [message #871094 is a reply to message #871092] Thu, 10 May 2012 15:48 Go to previous message
That would be great!
I'll be on the lookout Very Happy
Previous Topic:values of user properties are not being passed properly between report generation and report render
Next Topic:Dynamic axis markers
Current Time: Sat Jul 26 03:18:44 EDT 2025
Powered by FUDForum. Page generated in 0.11985 seconds
