Home » Archived » BIRT » How to display zero value (How to display zero value in the bar chart value series.)
How to display zero value [message #870854] Wed, 09 May 2012 19:53 Go to next message
Attached the sample file and report design.
Thanks in advance
AR
Re: How to display zero value [message #871056 is a reply to message #870854] Thu, 10 May 2012 12:56 Go to previous messageGo to next message
Select the y-axis scale on the third tab of the chart wizard. Enter 0
as a minimum value and check the show values outside axis range check
box. See attached screenshot.
Jason
> Thanks in advance
> AR
Re: How to display zero value [message #871057 is a reply to message #870854] Thu, 10 May 2012 12:56 Go to previous messageGo to next message
Jason
> Thanks in advance
> AR
Re: How to display zero value [message #871058 is a reply to message #870854] Thu, 10 May 2012 12:56 Go to previous messageGo to next message
Jason
> Thanks in advance
> AR
Re: How to display zero value [message #871060 is a reply to message #870854] Thu, 10 May 2012 12:56 Go to previous messageGo to next message
Jason
> Thanks in advance
> AR
Re: How to display zero value [message #871062 is a reply to message #870854] Thu, 10 May 2012 12:56 Go to previous messageGo to next message
Jason
> Thanks in advance
> AR
Re: How to display zero value [message #871063 is a reply to message #870854] Thu, 10 May 2012 12:56 Go to previous messageGo to next message
Jason
> Thanks in advance
> AR
Re: How to display zero value [message #871066 is a reply to message #870854] Thu, 10 May 2012 12:56 Go to previous messageGo to next message
Jason
> Thanks in advance
> AR
Re: How to display zero value [message #871068 is a reply to message #870854] Thu, 10 May 2012 12:56 Go to previous messageGo to next message
Jason
> Thanks in advance
> AR
Re: How to display zero value [message #871069 is a reply to message #870854] Thu, 10 May 2012 12:56 Go to previous messageGo to next message
Jason
> Thanks in advance
> AR
Re: How to display zero value [message #871071 is a reply to message #870854] Thu, 10 May 2012 12:56 Go to previous messageGo to next message
Jason
> Thanks in advance
> AR
Re: How to display zero value [message #871107 is a reply to message #871062] Thu, 10 May 2012 17:12 Go to previous messageGo to next message
Hi Jason,
Thanks for the response. It worked for me. Here I am facing one problem in case of few reports, that is : " The fisrt bar is missing from the chart".
Please suggest. For ur ref here I am attaching screen capture.
Thanks in advance
AR
Re: How to display zero value [message #871251 is a reply to message #871107] Fri, 11 May 2012 12:08 Go to previous messageGo to next message
Is the value for Planning and Analyze a null? If so add this script to
the chart:
function afterDataSetFilled(series, dataSet, icsc)
var list = dataSet.getValues();
for ( i=0; i<list.length; i=i+1)
if ( list[i] == null )
list[i]= 0;
Jason
On 5/10/2012 5:12 PM, Amar Reddy wrote:
> Hi Jason,
> Thanks in advance
> AR
Re: How to display zero value [message #871305 is a reply to message #871251] Fri, 11 May 2012 16:35 Go to previous messageGo to next message
Thanks Jason Smile
It really works without issue.
Happy Weekend My dear friend
Amarnath
Re: How to display zero value [message #1693100 is a reply to message #871251] Tue, 21 April 2015 13:36 Go to previous messageGo to next message
I need the chart to change a value on X-axis if "0" to "1" , so that I can display a small width of the bar graph for 0 value instead of a blank column.
How do I achieve this? I will not be jeopardizing the data because another column will accurately display the actual value as text.
I am using BIRT RCP designer 4.4.2
Please see attachment for example.
Re: How to display zero value [message #1693295 is a reply to message #1693100] Wed, 22 April 2015 21:20 Go to previous messageGo to next message
You should be able to do just like the above code in the afterdatasetfilled method only changing 0 values to 1.
Re: How to display zero value [message #1693352 is a reply to message #871058] Thu, 23 April 2015 08:32 Go to previous messageGo to next message
Hi Jasson ,
I am trying the same to show the zero value in Y -Axis but the data set is not allowing me do generate any report. Details screen shot has been attached below . Please find the same and do the needful. I have tried taking all types of data types but still it showing the same error. i.e "Can covert the data type : to value of double type"
Thanks % Regards:
kshirod Mishra
  • Attachment: Eclipse.docx
    (Size: 199.07KB, Downloaded 188 times)
Re: How to display zero value [message #1693384 is a reply to message #1693295] Thu, 23 April 2015 11:48 Go to previous messageGo to next message
you mean
if ( list[i] == 0 )
list[i]= 1;
?? I tried this to no luck.
Re: How to display zero value [message #1693993 is a reply to message #1693384] Wed, 29 April 2015 17:10 Go to previous messageGo to next message
Actually that worked, thanks!!!
Re: How to display zero value [message #1711296 is a reply to message #1693993] Wed, 14 October 2015 12:15 Go to previous message
The script above worked for me at that time, and months later when i open up my report design file, this part of the script has mysteriously vanished. So has some visibility settings, sorting etc
Instead I find the below for 'onRender' for the chart:
function afterDataSetFilled( series, dataSet, icsc )
if(series.getSeriesIdentifier() != ""){
if(dataSet.getValues()[0] == 0){
dataSet.getValues()[0] = 1;
icsc.getExternalContext().getScriptable().setPersistentGlobalVariable(series.getSeriesIdentifier(),"not null");
function beforeDrawDataPointLabel( dph, label, icsc )
if(icsc.getExternalContext().getScriptable().getPersistentGlobalVariable(dph.getSeriesDisplayValue()) != null){
label.getCaption().setValue("0");
* Called before populating the series dataset using the DataSetProcessor.
* @param series
* Series
* @param idsp
* IDataSetProcessor
* @param icsc
* IChartScriptContext
function beforeDataSetFilled( series, idsp, icsc )
But this script does not display a small bar for 0 values.
I tried adding:
if ( list[i] == 0 )
list[i]= 1;
Not working. Why do you think this happened? I am positive I have not made these changes. How do I go back to fixing the 0 value on the chart.
Thanks a lot for your help.
Previous Topic:XML values not enlisting
Next Topic:BIRT 4.5 XLSX Export using ExcelEmitter.TemplateFile
Current Time: Wed Jul 23 20:32:20 EDT 2025
Powered by FUDForum. Page generated in 0.07456 seconds
