Home » Modeling » M2T (model-to-text transformation) » I've problems running an ATL M2T transformation from UML(Can you help me to understand what's the problem?)
I've problems running an ATL M2T transformation from UML [message #530963] Mon, 03 May 2010 04:20 Go to next message
This is the output the consolle gives to me:
org.eclipse.m2m.atl.engine.emfvm.VMException: Could not find model element Package from UML
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.ASM.registerOperations(ASM. java:232)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:176)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch (EMFVMLauncher.java:162)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch (EMFVMLauncher.java:135)
at org.eclipse.m2m.atl.core.service.LauncherService.launch(Laun cherService.java:135)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDel egate.launch(AtlLaunchConfigurationDelegate.java:222)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
Caused by: org.eclipse.m2m.atl.engine.emfvm.ASM$SignatureParsingExcepti on: Could not find model element Package from UML
at org.eclipse.m2m.atl.engine.emfvm.ASM.parseTypeInternal(ASM.j ava:408)
at org.eclipse.m2m.atl.engine.emfvm.ASM.parseType(ASM.java:368)
at org.eclipse.m2m.atl.engine.emfvm.ASM.registerOperations(ASM. java:229)
... 10 more
This is the file i'm running:
module UML2Autori;
create OUT: Autori from IN: UML;
uses UML2TXTLib;
-- Matched rules
rule repairBox {
from
r: UML!Class (r.isRepair())
to
rb: Autori!RepairBox (name<-r.name,rate<-r.getMTTR())
rule triggering {
from
t: UML!Association (t.isTrigger())
using {
repairName: String = t.getRepair().name;
triggeringevent: UML!CLass = t.getAffectedComponent();
to
a: Autori!TriggerArc (src<-repairName,dest<-triggeringevent.name)
do {
thisModule.searchRepair(triggeringevent,repairName);
rule component {
from
c: UML!Class (c.isComponent())
do {
thisModule.componentTranslation(c);
rule errorpropagation {
from
aUml: UML!Association (aUml.isErrorPropagation())
using {
source: UML!Class = aUml.startsFrom();
destination: UML!Class = aUml.endsTo();
to
arc: Autori!EventToGate (src<-source.name,dest<-destination.name + '_gate')
So can you help me?
Re: I've problems running an ATL M2T transformation from UML [message #530971 is a reply to message #530963] Mon, 03 May 2010 04:50 Go to previous messageGo to next message
--------------000609050509020306080502
ATL is an M2M technology, and its team mainly monitors the m2m
newsgroup, I've added it to the to: list of this answer so that they can
help you on your problem .
Laurent
> Java Stack:
> java:232)
> gin.java:1069)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> ava:408)
> java:229)
> ... 10 more
> module UML2Autori;
> uses UML2TXTLib;
> -- Matched rules
> rule repairBox {
> from r: UML!Class (r.isRepair())
> to
> rule triggering {
> from
> using {
> triggeringevent: UML!CLass = t.getAffectedComponent(); }
> to
> do {
> rule component {
> from c: UML!Class (c.isComponent())
> do {
> from aUml: UML!Association (aUml.isErrorPropagation())
> using {
> to
> + '_gate')
> So can you help me?
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------000609050509020306080502--
Re: I've problems running an ATL M2T transformation from UML [message #854535 is a reply to message #530963] Mon, 23 April 2012 23:12 Go to previous messageGo to next message
I got the amost same errors when run a application which use plugin of alt
Have you found the answer to youre problem?
It will be very nice if you could tell me why it produces such exceptions?
It seems the model to be transformed is not a vaild model, right?
BRs
[Updated on: Mon, 23 April 2012 23:13] by Moderator
Re: I've problems running an ATL M2T transformation from UML [message #870927 is a reply to message #854535] Thu, 10 May 2012 05:32 Go to previous messageGo to next message
i got almost the same problem.
"Could not find model element EPackage from Model
Java Stack"
have you got the answer?
Exception in thread "main" org.eclipse.m2m.atl.engine.emfvm.VMException: Could not find model element EPackage from Model
Java Stack:
Re: I've problems running an ATL M2T transformation from UML [message #870928 is a reply to message #530971] Thu, 10 May 2012 05:34 Go to previous messageGo to next message
could you add me to newsgroup m2m, so that i could ask some help for the almost same Error
"Exception in thread "main" org.eclipse.m2m.atl.engine.emfvm.VMException: Could not find model element EPackage from Model
Java Stack:...
BRs
Re: I've problems running an ATL M2T transformation from UML [message #870939 is a reply to message #870928] Thu, 10 May 2012 05:52 Go to previous message
M2M has been renamed MMT to avoid confusion with the increasingly
prevalent Machine-to-Machine usage.
Each MMT project now has its own newsgroup so try eclipse.atl.
Ed Willink
> Java Stack:...
> BRs
Previous Topic:[Galileo, XPAND] Plugin missing?
Next Topic:[Accele0 3] Quick start/Getting started problem
Current Time: Sat Jul 26 08:50:01 EDT 2025
Powered by FUDForum. Page generated in 0.07837 seconds
