Home » Archived » BIRT » Problem in previewing report in Birt designer 3.7 in Eclipse Indigo
Problem in previewing report in Birt designer 3.7 in Eclipse Indigo [message #870632] Wed, 09 May 2012 03:16 Go to next message
I have developed a report using BIRT Report Designer Release Build: 3.7.2 in Eclipse Indigo
I have installed Birt in Eclipse using following url:Install New Software->BIrt URL
Birt URL:BIRT Update Site
But when I preview the report in eclipse it is giving following error:
Error:
HTTP ERROR 500
Problem accessing /viewer/run. Reason:
javax/servlet/ServletConfig
Caused by:
java.lang.LinkageError: javax/servlet/ServletConfig
at org.eclipse.birt.report.utility.ParameterAccessor.initParameters(ParameterAccessor.java:1460)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.init(BirtSoapMessageDispatcherServlet.java:102)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.initializeDelegate(ServletManager.java:195)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:179)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:322)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:924)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:549)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Re: Problem in previewing report in Birt designer 3.7 in Eclipse Indigo [message #870810 is a reply to message #870632] Wed, 09 May 2012 14:35 Go to previous messageGo to next message
Can you try the allinone download?
http://download.eclipse.org/birt/downloads/
Jason
> Software->BIrt URL
> Error:
> HTTP ERROR 500
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problem in previewing report in Birt designer 3.7 in Eclipse Indigo [message #870877 is a reply to message #870810] Thu, 10 May 2012 03:02 Go to previous messageGo to next message
I tried to preview the report using Eclipse BIRT All-in-one and it worked.
But now I have another problem,when I run this report at runntime from a jsp using birt:viewer,the code for which is given below is is giving following error :
Error:
HTTP Status 404 - /Report/frameset
type Status report
message /Report/frameset
description The requested resource (/Report/frameset) is not available.
Apache Tomcat/6.0.30
I have also attached my report design and jsp file to view this report at runtime
Please help me out
Re: Problem in previewing report in Birt designer 3.7 in Eclipse Indigo [message #870953 is a reply to message #870632] Thu, 10 May 2012 06:47 Go to previous messageGo to next message
Please let me know what configuration to do in web.xml or if any other libraries or files to be added to view report at run time
Re: Problem in previewing report in Birt designer 3.7 in Eclipse Indigo [message #871078 is a reply to message #870953] Thu, 10 May 2012 13:49 Go to previous messageGo to next message
Do you have the birt viewer in a separate context than where that jsp
page is at? If so make sure tomcat has cross context enabled:
http://www.coderanch.com/t/536694/Tomcat/Setting-up-CrossContext-configuration-Tomcat
and do the following:
this can be done by copying the birt.tld file to your WEB-INF/tlds
directory and copying coreapi.jar, modelapi,jar, viewerservlets.jar,
engineapi.jar, and com.ibm.icu_version.jar from the Viewer libs
directory to the new context/web-inf/lib directory. Add the following
reference to your web.xml
<jsp-config>
<taglib>
<taglib-uri>/birt.tld</taglib-uri>
<taglib-location>/WEB-INF/tlds/birt.tld</taglib-location>
</taglib>
</jsp-config>
Using this approach reports are referenced in relation to the BIRT
Viewer not the new context. You can get the individual jars from the
osgi runtime download or just copy
org.eclipse.birt.runtime_3.7.2.version.jar
viewerservlets.jar
If the jsp is not in a separate context remove the baseURL attribute.
Jason
Re: Problem in previewing report in Birt designer 3.7 in Eclipse Indigo [message #871136 is a reply to message #871078] Fri, 11 May 2012 01:55 Go to previous messageGo to next message
I have added the jars as per you instructions.
Do we have to also configure birt viewer in tomcat.if so,how to do it.
i am running my application in eclipse using tomcat 6.0 server,so i am not clear what
about the context which is same as birt viewer or not:as i am executing the application at this url:
localhost:8080/fert_abc
I have modified the server.xml as:
<Context path="/fert_abc" debug="0" crossContext="true"/>
Is this what u were telling me to do.
Please tell me if there are any more changes i have to do as mu report is still not displaying
My web.xml is as follows:
<web-app>
<display-name>fert_abc</display-name>
<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
</listener>
<listener>
<listener-class>
org.springframework.web.util.IntrospectorCleanupListener</listener-class>
</listener>
<context-param>
<description>
This context parameter specifies the name and location of the Tiles Definitions file.
</description>
<param-name>org.apache.tiles.impl.BasicTilesContainer.DEFINITIONS_CONFIG</param-name>
<param-value>/WEB-INF/classes/tiles.xml</param-value>
</context-param>
<listener>
<listener-class>org.apache.struts2.tiles.StrutsTilesListener</listener-class>
</listener>
<filter>
<filter-name>struts2</filter-name>
<filter-class>org.apache.struts2.dispatcher.ng.filter.StrutsPrepareAndExecuteFilter</filter-class>
</filter>
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
<welcome-file-list>
<welcome-file>index.jsp</welcome-file>
</welcome-file-list>
<jsp-config>
<taglib>
<taglib-location>/WEB-INF/tld/birt.tld</taglib-location>
</taglib>
</jsp-config>
</web-app>
Re: Problem in previewing report in Birt designer 3.7 in Eclipse Indigo [message #871252 is a reply to message #871136] Fri, 11 May 2012 12:13 Go to previous message
If looks like you ware writing your own app and need to reference the
BIRT viewer in another context. Copy the WebViewerExample directory
from the birt runtime download to your webapps directory in your tomcat
install. Rename it to BirtViewer.
Add
<Context path="/BirtViewer" docBase="BirtViewer"
debug="5" reloadable="true" crossContext="true">
to your server config and set the baseURL attribute in your app jsp page
to /BirtViewer. Restart tomcat and try that.
Bear in mind that the report needs to be under the BirtViewer.
Jason
> not clear what
> <web-app>
> <listener>
> </listener>
> <listener>
> <listener-class>
> </listener>
> <context-param>
> <description>
> Definitions file.
> </description>
> </context-param>
> <listener>
> </listener>
> <filter>
> </filter>
> <filter-mapping>
> </filter-mapping>
> <welcome-file-list>
> <jsp-config>
> <taglib>
> </taglib>
> </jsp-config>
> </web-app>
Previous Topic:Detail records in Master-Detail report do not change
Next Topic:Adding comments to the graph generated by BIRT.
Current Time: Sat Jul 26 18:13:13 EDT 2025
Powered by FUDForum. Page generated in 0.04601 seconds
