Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How can a widget be disposed without a call to dispose()?
How can a widget be disposed without a call to dispose()? [message #870858] Wed, 09 May 2012 21:59 Go to next message
How is it possible for a widget to be disposed if its dispose() was never called? I'm seeing an odd bug in an RCP app that shows up as:
org.eclipse.swt.SWTException: Widget is disposed
So I set a breakpoint in
Widget.dispose()
to find out how/why it was being disposed. To my surprise, the breakpoint was never hit for the widget in question.
Here's the top of the stack trace:
	at org.eclipse.swt.SWT.error(SWT.java:4282)
	at org.eclipse.swt.SWT.error(SWT.java:4197)
	at org.eclipse.swt.SWT.error(SWT.java:4168)
	at org.eclipse.swt.widgets.Widget.error(Widget.java:774)
	at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:568)
	at org.eclipse.swt.widgets.Widget.addDisposeListener(Widget.java:467)
	at org.eclipse.jface.fieldassist.ControlDecoration.addControlListeners(ControlDecoration.java:602)
	at org.eclipse.jface.fieldassist.ControlDecoration.<init>(ControlDecoration.java:476)
	at org.eclipse.jface.fieldassist.ControlDecoration.<init>(ControlDecoration.java:428)
This is an RCP app built against a 3.7.2 target platform.
[Updated on: Wed, 09 May 2012 22:02] by Moderator
Re: How can a widget be disposed without a call to dispose()? [message #871088 is a reply to message #870858] Thu, 10 May 2012 14:51 Go to previous messageGo to next message
You'd have to add a dispose listener to the widget when it's created to find out when it is disposed. In SWT, if I dispose a Composite, it disposes all of its children. Their dispose isn't called, but they would get SWT.Dispose events.
PW
Re: How can a widget be disposed without a call to dispose()? [message #871098 is a reply to message #871088] Thu, 10 May 2012 16:20 Go to previous message
Thanks, Paul. I didn't know widgets would be disposed that way without their dispose() being called. I'll set up a dispose listener to see if I can find what's happening.
Previous Topic:Problem forcing focus in combo text field
Next Topic:SWT equivalent of AWT Component.addNotify()
Current Time: Fri Jul 18 03:16:57 EDT 2025
Powered by FUDForum. Page generated in 0.31590 seconds
