Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [TEXO] xsd mappings
[TEXO] xsd mappings [message #870730] Wed, 09 May 2012 09:26 Go to next message
The XSD is converting to Java, applying changes automatically using the ecore/annotations model really well. Thank you.
I have though just found out the system which will handle part of the processing is expecting JAXB bindings to have been applied. e.g.
xs:integer --> int rather than java.math.BigInteger
Is it possible to annotate the ecore ePackage to override default mappings and instead map xs:integer to int?
Gary
Re: [TEXO] xsd mappings [message #870828 is a reply to message #870730] Wed, 09 May 2012 15:38 Go to previous message
Hi Gary,
Hmm, can't be changed/controlled easily (at least not without coding), but maybe I can add a JAXB compliant mode. Are
you aware of other simple type mismatches between EMF and jaxb?
See the last pages of the attached pdf for an overview of the xsd-ecore mappings.
Can you enter a bugzilla for this then we can take it from there.
gr. Martin
On 05/09/2012 03:26 PM, Gary Godfrey wrote:
> applied. e.g.
> Regards,
> Gary
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Previous Topic:Integrate EMF Search with GMF
Next Topic:[EEF] Customizing EEF Generation
Current Time: Sun Jul 27 15:35:43 EDT 2025
Powered by FUDForum. Page generated in 0.02913 seconds
