Home » Language IDEs » C / C++ IDE (CDT) » How to change the default build configurations when create a new project?
How to change the default build configurations when create a new project? [message #837139] Thu, 05 April 2012 06:05 Go to next message
Hi all:
Is there any way(setting or hack) to change default build settings which are used when I create new project in Eclipse CDT? Some of toolchain setting I have to change every time I creating new project(For example:PC-LINT configuration for every project).
thanks!
index.php/fa/7794/0/
  • Attachment: xxx.bmp
    (Size: 881.19KB, Downloaded 1815 times)
[Updated on: Wed, 09 May 2012 03:45] by Moderator
Re: How to change build configurations when create a new project? [message #870637 is a reply to message #837139] Wed, 09 May 2012 03:33 Go to previous messageGo to next message
help...
Re: How to change build configurations when create a new project? [message #870716 is a reply to message #870637] Wed, 09 May 2012 08:36 Go to previous messageGo to next message
You can't change it in creation of your project.
But you can delete it and add an other one in Manage configuration
Re: How to change build configurations when create a new project? [message #870871 is a reply to message #870716] Thu, 10 May 2012 02:27 Go to previous message
thanks for your answer!
but change the config every time is a nasty thing......
a solution is create an empty project and config with what i want,then i can copy this project when i want to create a new project~
another solution is:if i can find out where the default config is stored,i can change it,ha~but unfortunately,i don't know where it is,maybe i have to change the source code of the CDT(it's difficult for me)......
Previous Topic:Unable to get $PATH.
Next Topic:Problems to make the debugger work
Current Time: Sun Jul 20 20:56:59 EDT 2025
Powered by FUDForum. Page generated in 0.17794 seconds
