Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [TEXO] Enum values
[TEXO] Enum values [message #870678] |
Wed, 09 May 2012 06:19  |
I have an enum defined in my XSD and want to automatically create the RuleType.java enum so that we get something closer to :
[size=2]public enum RuleType {
1,
2;
}[/size]
The XSD will contain many enumerations. I would prefer to set the default behaviour once for the whole model rather than adding an annotaion to each enum. Any ideas on how this can be implemented please?
The XSD:
<xs:simpleType name="RuleType">
<xs:restriction base="xs:string">
<xs:enumeration value="1">
<xs:annotation>
<xs:documentation>Aggregation</xs:documentation>
</xs:annotation>
</xs:enumeration>
<xs:enumeration value="2">
<xs:annotation>
<xs:documentation>Flash</xs:documentation>
</xs:annotation>
</xs:enumeration>
</xs:restriction>
</xs:simpleType>[/size]
The system working with the generated Java model, is looking to use RuleType.1 etc.
The currently generated Java class:
* The enum: _1 <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
_1(0, "_1", "1")
* @return always true for this instance
* @generated
public boolean is_1()
return true;
* The enum: _2 <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
_2(1, "_2", "2")
* @generated
public boolean is_2()
return true;
};[/size]
Gary
Re: [TEXO] Enum values [message #870689 is a reply to message #870678] |
Wed, 09 May 2012 07:06   |
Hi Gary,
Afaik 1 or 2 invalid java identifiers, I tried your RuleType with 1 and 2, but Eclipse doesn't like it. Can you
post/attach/send a java file which compiles correctly in your ide?
gr. Martin
On 05/09/2012 12:19 PM, Gary Godfrey wrote:
> to :
> 1,
> 2;
> The XSD:
> <xs:annotation>
> </xs:annotation>
> </xs:enumeration>
> <xs:annotation>
> </xs:annotation>
> </xs:enumeration>
> </xs:restriction>
> * * @generated
> _1(0, "_1", "1")
> * @generated
> @Override
> return true;
> * * @generated
> _2(1, "_2", "2")
> * @generated
> @Override
> return true;
> };[/size]
> Regards,
> Gary
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [TEXO] Enum values [message #871638 is a reply to message #870709] |
Mon, 14 May 2012 11:38   |
Hi Martin,
I now been supplied with a valid XSD enum which needs to be mapped to a Java enum:
<xs:simpleType name="CreditRating">
<xs:enumeration value="Excellent"/>
<xs:enumeration value="Good"/>
<xs:enumeration value="Fair"/>
<xs:enumeration value="Poor"/>
<xs:enumeration value="Doh!"/>
</xs:restriction>
</xs:simpleType>
This creates:
public enum CreditRating
* The enum: EXCELLENT <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
EXCELLENT(0, "Excellent", "Excellent")
* @generated
public boolean isExcellent()
return true;
* The enum: GOOD <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
GOOD(1, "Good", "Good")
* @generated
public boolean isGood()
return true;
Is it possible to generate a simple Enum as follows please?
EXCELLENT,
GOOD,
FAIR,
POOR,
BAD;
Gary
Re: [TEXO] Enum values [message #871641 is a reply to message #871638] |
Mon, 14 May 2012 11:43   |
Hi Gary,
It is possible with your own template, that's quite doable. See this wiki page:
http://wiki.eclipse.org/Texo/Template_Overriding
and use this template as a base (just get rid of most of its content):
http://git.eclipse.org/c/texo/org.eclipse.emf.texo.git/tree/generator/org.eclipse.emf.texo.modelgenerator/src/org/eclipse/emf/texo/modelgenerator/templates/enum.xpt
Note that I am not sure why the current enum does not work for you, the result is quite similar to what you want. Can
you let me know why the current Texo enum does not work for you?
gr. Martin
On 05/14/2012 05:38 PM, Gary Godfrey wrote:
> Hi Martin,
> </xs:restriction>
> </xs:simpleType>
> This creates:
> * * @generated
> * @generated
> @Override
> return true;
> * * @generated
> * @generated
> @Override
> return true;
> EXCELLENT,
> GOOD,
> FAIR,
> POOR,
> BAD;
> Regards,
> Gary
The Netherlands
Re: [TEXO] Enum values [message #882983 is a reply to message #882954] |
Thu, 07 June 2012 11:22  |
Hi Gary,
Hmm, I don't have a good solution right away... I think the best you can do is write a short java program which reads
the ecore and sets all names to be the same as the literal and then saves the ecore.
But why do the generated code and the xsd need to match? Afaik the xml which gets generated from the code should be
correct and follow the xsd, right?
gr. Martin
On 06/07/2012 04:17 PM, Gary Godfrey wrote:
> Hi Martin,
> In a supplied XSD, some xs:enumerations contain an underscore.
> <xs:simpleType name="TelephoneType">
> <xs:enumeration value="TETY_1">
> <xs:annotation>
> <xs:documentation>Mobile</xs:documentation>
> </xs:annotation>
> </xs:enumeration>
> <xs:enumeration value="TETY_2">
> <xs:annotation>
> <xs:documentation>LandLine</xs:documentation>
> </xs:annotation>
> </xs:enumeration>
> </xs:restriction>
> </xs:simpleType>
> The generated .ecore file removes the underscore from the name attribute. Is it possible to maintain the exact value
> from the XSD?
> <eClassifiers xsi:type="ecore:EEnum" name="TelephoneType">
> <eAnnotations source="org/eclipse/emf/ecore/util/ExtendedMetaData">
> <details key="name" value="TelephoneType"/>
> </eAnnotations>
> <eLiterals name="TETY1" literal="TETY_1">
> <eAnnotations source="emf/2002/GenModel">
> <details key="documentation" value="Mobile"/>
> </eAnnotations>
> </eLiterals>
> <eLiterals name="TETY2" value="1" literal="TETY_2">
> <details key="documentation" value="LandLine"/>
> </eAnnotations>
> </eLiterals>
> </eClassifiers>
> To ensure the XSD and generated Enum match I have worked around this by altered my custom enum.xpt to use the 'literal'
> attribute instead of the 'name' attribute when generating the Java Enum.
> public enum «this.simpleClassName»
> «EXPAND org::eclipse::emf::texo::modelgenerator::templates::enum_addition::root(modelController) FOR this»
> «FOREACH eEnum.ELiterals AS e SEPARATOR ","-»
> «LET ((EEnumLiteral)e) AS el-»
> * The enum: «toUpperCase(el.literal)»
> * <!-- begin-user-doc -->
> * <!-- end-user-doc -->
> * @generated
> «modelController.getJavaAnnotations(el, "field")-»
> «ENDLET-»
> «ENDFOREACH-»;
> The Java Enum has the required values.
> public enum TelephoneType
> * The enum: TETY_1 <!-- begin-user-doc --> <!-- end-user-doc -->
> * * @generated
> TETY_1
> * The enum: TETY_2 <!-- begin-user-doc --> <!-- end-user-doc -->
> * * @generated
> TETY_2
> How though can I ensure entities which set a default value use the literal rather than the name of the feature annotation?
> public class Telephone {
> private TelephoneType telephoneType = TelephoneType.TETY1; // COMPILE ERROR
> I have looked at the entity.xpt and see it uses «featureAnnotation.defaultValue», but I cannot see where the
> defaultValue is determined.
> private «featureAnnotation.type» «featureAnnotation.validJavaMemberName» = «featureAnnotation.defaultValue»;
> Regards,
> Gary
The Netherlands
Current Time: Sun Jul 27 03:54:35 EDT 2025
Powered by FUDForum. Page generated in 0.05841 seconds
