Home » Modeling » QVT-OML » Error "ObjectDeclsCS" expected after "object"
Error "ObjectDeclsCS" expected after "object" [message #870543] Tue, 08 May 2012 11:47 Go to next message
In a qvto script I have this object creation:
object {
ownedMember += ownedPackages->collect(thisPackage |
createPackage(thisPackage))->asOrderedSet();
The dynamic interpretor (red crossed circle) shows me the following error:
How can it be fix.
Thanks.
Re: Error "ObjectDeclsCS" expected after "object" [message #870556 is a reply to message #870543] Tue, 08 May 2012 12:36 Go to previous messageGo to next message
+= looks suspect.
When a complicated expression doesn't work, make it simpler till it does
then all becomes clear.
Ed Willink
On 08/05/2012 16:47, Alain Lavoie wrote:
> Hello,
> object {
> error:
> How can it be fix.
> Thanks.
Re: Error "ObjectDeclsCS" expected after "object" [message #870600 is a reply to message #870556] Tue, 08 May 2012 18:02 Go to previous messageGo to next message
Ed Willink a écrit :
> += looks suspect.
This comes from an extract of the [Quick Start Guide to MDA]
from Borland.
I will avoid mixing Qvt samples from different implementors.
Thanks.
Re: Error "ObjectDeclsCS" expected after "object" [message #870622 is a reply to message #870600] Wed, 09 May 2012 02:23 Go to previous messageGo to next message
HI
You're not mixing implementors; just using vintage or inadequately
proof-read material.
Quick Start Guide to MDA is dated September 2006, and refers to OMG document
ptc/05-11-01 (MOF 2.0 Query/View/Transformation final adopted
specification).
The specification has not changed significantly since then. Looking at
the spec, I can find no justification for "object" in
mapping ... {
init { ... }
object { ... }
It seems that this usage of "object" was recognised to be redundant (in
perhaps 2004/2005) so that the syntax is
mapping ... {
init { ... }
optionally
mapping ... {
init { ... }
population { ... }
The residual usage of object is as a type constructor in an expression
object s:Schema {
name := self.name;
table := self.ownedElement->map class2table();
where += is an option, but not normally necessary since you start from
scratch.
If you're going to use QVTo, you should familiarize yourself with the
specification; it's not perfect but at least gives a vendor-independent
view of what should be right.
Ed Willink
> > += looks suspect.
> does
> from Borland.
> Thanks.
Re: Error "ObjectDeclsCS" expected after "object" [message #870728 is a reply to message #870622] Wed, 09 May 2012 09:23 Go to previous message
> HI
Excellent answer. Thanks, I will follow your advises.
Regards.
Previous Topic:Failed to resolve metamodel when debugging
Next Topic:Using oclIsTypeOf() with a variable argument
Current Time: Fri Jul 25 19:52:27 EDT 2025
Powered by FUDForum. Page generated in 0.04769 seconds
