Insert Text / Replace Text / Click in Component not working [message #870526] |
Tue, 08 May 2012 10:30  |
I just started working with Jubula. The first tests are running, but now I have some strange behaviour. I would like to test some text fileds in our application. I can verify if a text field is editable. And everything works correctly. The test passes, when the text field is editable and fails if it is not.
As next step I want to enter some text in an editable text field I checked before. Therefor I used the 'Insert Text' functionality. This always fails. I also tried to use 'Replace Text' instead, but it does not work either.
Afterwards I tried to take smaller steps and start with 'Click in Component', but that fails, too.
I am using jubula 1.2.0 on windows. The application under test is written using several external jars and make heavily use of spring and aspect oriented programming.
Any hints how I can start to find find the problem, why jubula does not work with these text fields? Is there any way to get more information, why clicking into the component fails?
Kind regards,
Torsten
FUDForum. Page generated in 0.07169 seconds
