Mapping Problem Jlabel & JTable in tabbed panel/panel [message #870496] |
Tue, 08 May 2012 08:43  |
Hey all,
I try to evaluate Jubula at the moment, everything works fine till now.
I have a problem with mapping a normal label component, the label is part of a Tabbed panel and in the mapping mode there is a green square around it but Jubula don't get the technical component name.
Another Component I can't map is a JTable component in another tabbed panel the problem is the same as above the green square appears but no technical name is assigned. The table is shown, after the user choose a entry from another table and click a button.
The Application to test is in Java and using swing.
Thank you in advance for your Help!
Sincerely Simon
Re: Mapping Problem Jlabel & JTable in tabbed panel/panel [message #872102 is a reply to message #872013] |
Tue, 15 May 2012 09:15  |
If JXLabel extends JLabel, then it should be recognized automatically. You can put a ticket in for this. In terms of the question about the extension, I'm afraid I don't know. I'd recommend having a look at the examples in the links I gave above. Perhaps other community members can comment as well. There is also the option of professional support if you want individual help with any extensions.
Alex
FUDForum. Page generated in 0.05483 seconds
