Home » Eclipse Projects » Eclipse 4 » Question about @EventTopic annotations
Question about @EventTopic annotations [message #870134] Sun, 06 May 2012 17:38 Go to next message
Hi everybody,
I am playing with the IEventBroker service and @EventTopic injections
but I have some unexpected behaviors that I don't understand, so I am
asking for some help.
I am using Eclipse Juno M6 + Eclipse E4 Tools + Eclipse E4 Tools Bridge
for 3.x
Basically I have two POJOs (PublishView and SubscribeView) that define
two views, one with a button for posting events, and the other one which
defines a handler.
I also have two DIViewPart for displaying these views inside an instance
of the SDK.
The code is pretty straighforward and it's here:
http://pastebin.com/dTTq4Knw
The PublishView has an injected IEventBroker field so that I can do a
eventBroker.send("foo", "Hello") when the button is pressed.
The SubscribeView has the following method for handling the events
posted on the "foo" topic:
@Inject
public void handleFoo(@EventTopic("foo") Object data) {
System.out.format("Received foo: %s\n", data);
Now, what I expected was to see on the console a "Received foo: hello"
message each time I press the button. But, instead, I have the following
behavior:
1) If I run the plugin in the SDK, at startup I see on the console a
message like this one:
Received foo:
org.eclipse.equinox.console.command.adapter.CommandProviderAdapter@217a26f4
1.1) When I click the button, eventBroker.send("foo", "hello") is called
but nothing is received by the handler
2) If I run the plugin as an E4 RCP application, at startup I see on the
console the following exception:
org.eclipse.e4.core.di.InjectionException: Unable to process
"SubscribeView#handleFoo()": no actual value was found for the argument
"Object[@org.eclipse.e4.ui.di.UIEventTopic(value=foo)]".
2.1) If I click the button everything works. I correctly see "Received
foo: Hello" messages on the console every time I press the button.
Now the questions are:
* What are the two "spurious" events that I receive at startup? I mean,
"foo" is not a topic that should be used anywhere in the platform, so
why do I receive events from the platform on that topic?
* Why the brokering mechanism doesn't work in the SDK while it seems to
work fine in the RCP application? Is it a limitation of the Bridge?
Thank you for your help.
-Fabio
Re: Question about @EventTopic annotations [message #870169 is a reply to message #870134] Mon, 07 May 2012 02:56 Go to previous messageGo to next message
Am 06.05.12 23:38, schrieb Fabio Mancinelli:
> Hi everybody,
> for 3.x
> defines a handler.
> of the SDK.
> @Inject
> behavior:
> Received foo:
You should put a @Optional in there and the message will go away.
It looks like the event injection code is not stepping in correctly
Need to check this but there should not be a difference. I'll come back
once I tried this my own.
Tom
Re: Question about @EventTopic annotations [message #870292 is a reply to message #870169] Mon, 07 May 2012 11:10 Go to previous messageGo to next message
Ok 2 observations:
a) One needs to use @Optional
b) One should not use Object (to me this looks like a bug because it
looks like if there's a key stored in the IEclipseContext things
break the event system injection!)
Tom
Re: Question about @EventTopic annotations [message #870293 is a reply to message #870292] Mon, 07 May 2012 11:12 Go to previous messageGo to next message
Here the method for reference
> @Inject
> @Optional
> void eventReceived(@UIEventTopic("foo") String data) {
> if( data != null && viewer != null) {
> viewer.add(data);
Am 07.05.12 17:10, schrieb Tom Schindl:
> Ok 2 observations:
> Tom
Re: Question about @EventTopic annotations [message #870309 is a reply to message #870292] Mon, 07 May 2012 11:47 Go to previous messageGo to next message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=378694 my suggested
workaround would be to use @Named("__DUMMY__").
Tom
> Ok 2 observations:
> Tom
Re: Question about @EventTopic annotations [message #870367 is a reply to message #870293] Mon, 07 May 2012 16:01 Go to previous messageGo to next message
>> @Inject
>> @Optional
>> if( data != null&& viewer != null) {
>> viewer.add(data);
Thanks Tom. It worked perfectly.
I was pretty sure of having also done a test using the String data
parameter but it was not the case.
Thanks again,
Fabio
>> Ok 2 observations:
>> Tom
Re: Question about @EventTopic annotations [message #870373 is a reply to message #870367] Mon, 07 May 2012 16:40 Go to previous messageGo to next message
If you add @Named() like described in the bug this ensures you don't get
broken if someone pushed something with java.lang.String into the a
parent IEclipseContext!
Not sure this bug gets fixed for 4.2!
Tom
Am 07.05.12 22:01, schrieb Fabio Mancinelli:
>>> @Inject
>>> @Optional
>>> viewer.add(data);
> Thanks again,
> Fabio
>>> Ok 2 observations:
>>> Tom
Re: Question about @EventTopic annotations [message #992827 is a reply to message #870373] Sat, 22 December 2012 14:14 Go to previous message
This works:
@Inject
@Optional
void onRemoveTags(@UIEventTopic(Topics.COMMAND_REMOVE_TAGS) String object)
called by:
broker.post(Topics.COMMAND_REMOVE_TAGS, null);
However this code is not called from the broker, but IS called during startup with org.eclipse.equinox.console.command.adapter.CommandProviderAdapter as the object
@Inject
@Optional
void onRemoveTags(@UIEventTopic(Topics.COMMAND_REMOVE_TAGS) Object object)
I would assume that using a specified @UIEventTopic would be on par with using @Named and should be properly resolved, even with Object as the parameter. I am using the latest 4.3 stream build.
Previous Topic:Background image on main shell
Next Topic:E4 to RAP Migration
Current Time: Wed Jul 23 07:45:30 EDT 2025
Powered by FUDForum. Page generated in 0.08299 seconds
