Home » Modeling » TMF (Xtext) » [Solved] Custom content Assist
[Solved] Custom content Assist [message #870256] Mon, 07 May 2012 09:25 Go to next message
I have a problem with my content assist,
I try to apply a label provider on my content assist but there is no effect
i use :
public void configureContentProposalLabelProvider(Binder binder) {
binder.bind(ILabelProvider.class).
annotatedWith(ContentProposalLabelProvider.class).
to(MyLabelProvider.class);
with
MyLabelProvider contains method getText() and getImage() for grammar element's...
Fred.
[Updated on: Thu, 10 May 2012 12:28] by Moderator
Re: Custom content Assist [message #870349 is a reply to message #870256] Mon, 07 May 2012 13:51 Go to previous messageGo to next message
can you share a testcase (grammar + labelprovider) as well
~Christian
Re: Custom content Assist [message #870352 is a reply to message #870349] Mon, 07 May 2012 13:54 Go to previous messageGo to next message
Btw why didnt you simply implement the already generated org.xtext.example.mydsl.ui.labeling.MyDslLabelProvider
Re: Custom content Assist [message #870481 is a reply to message #870256] Tue, 08 May 2012 07:50 Go to previous messageGo to next message
I have MylabelProvider for custom Outline view...
but the style don't work on my content assist !
so i search to do a link between the element...
Freddy.
Re: Custom content Assist [message #870576 is a reply to message #870481] Tue, 08 May 2012 15:27 Go to previous messageGo to next message
you still did not answer my first question
~Christian
Re: Custom content Assist [message #870595 is a reply to message #870256] Tue, 08 May 2012 17:21 Go to previous messageGo to next message
hum sorry... Sad
so an example :
MylabelProvider.java :
String text(EnumDecl enumD) {
return enumD.getEnumName().getName();
String image(EnumDecl enumD) {
return "enum.gif";
MyDsl.xtext :
EnumDecl: enumName=EnumName leftC=LeftCurlyBracket propertyEnum+=EnumPropertyName (comma+=Comma propertyEnum+=EnumPropertyName)* rightC=RightCurlyBracket;
result in outline vieuw :
www.hostingpics.net/viewer.php?id=962805enum.jpg
I would have the same icon in my content assist
Freddy.
Re: Custom content Assist [message #870598 is a reply to message #870595] Tue, 08 May 2012 17:33 Go to previous messageGo to next message
I do not see any cross refs in the grammar you posted so there might
be a missanderstanding in what the label provider is used for.
Re: Custom content Assist [message #870671 is a reply to message #870256] Wed, 09 May 2012 06:04 Go to previous messageGo to next message
I do not understand what you want...
sorry for my english very limit Embarrassed
Freddy.
Re: Custom content Assist [message #870675 is a reply to message #870671] Wed, 09 May 2012 06:08 Go to previous messageGo to next message
Hi try to find out if the label provider that is injected to the
content assist is ever called for the place you are talking about. I
guess the answer is not. Never the less you can customize the
Complete methods in the proposal provider and call
createCompletionproposal with an image
Re: Custom content Assist [message #870687 is a reply to message #870256] Wed, 09 May 2012 06:58 Go to previous messageGo to next message
by default the labelprovider applies to every element?
and well it just is not for my content assist !
this is why I thought that the method "configureContentProposalLabelProvider" should be used
Re: Custom content Assist [message #870696 is a reply to message #870687] Wed, 09 May 2012 07:28 Go to previous messageGo to next message
No! what i say: it is only used for cross references and you do not have any cross refs
so it is not used at all in your case.
Re: Custom content Assist [message #870699 is a reply to message #870696] Wed, 09 May 2012 07:34 Go to previous messageGo to next message
aaaaaah yes!
but then, what is the cross references ?!
Re: Custom content Assist [message #870701 is a reply to message #870699] Wed, 09 May 2012 07:49 Go to previous messageGo to next message
If you have something like ref=[Type] in your grammar. You don't have
=> you have to find a different solution. So have a look at the
complete methods in your proposal provider
Re: Custom content Assist [message #870742 is a reply to message #870701] Wed, 09 May 2012 10:04 Go to previous messageGo to next message
my proposal provider is empty...
How do I implement method or have you a link for documentation ?
Re: Custom content Assist [message #870746 is a reply to message #870742] Wed, 09 May 2012 10:06 Go to previous messageGo to next message
See the abstract generated superclass
Re: Custom content Assist [message #870757 is a reply to message #870746] Wed, 09 May 2012 10:41 Go to previous messageGo to next message
i have method for example :
public void completeEnumDecl_EnumName(EObject model, Assignment assignment, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
completeRuleCall(((RuleCall)assignment.getTerminal()), context, acceptor);
i don't see where i can to change style..
Re: Custom content Assist [message #870804 is a reply to message #870757] Wed, 09 May 2012 14:17 Go to previous messageGo to next message
you did not post your complete grammar. thus its hard to tell how this could look like.
so let us asume your grammar would look like
EnumDecl: enumName=ID "{" propertyEnum+=ID ("," propertyEnum+=ID)* "}";
then you could do
public class MyDslProposalProvider extends AbstractMyDslProposalProvider {
	@Inject
	private IImageHelper imageHelper;
		//icons/"Entity.gif
		acceptor.accept(createCompletionProposal("EnumName", "New EnumName", imageHelper.getImage("Entity.gif"), context));
Re: Custom content Assist [message #870947 is a reply to message #870256] Thu, 10 May 2012 06:21 Go to previous messageGo to next message
Ok ok
one last problem,
MyDSLProposalProvider is correctly call
but the method no... i think to need constructor or a method configure ?
Re: Custom content Assist [message #870949 is a reply to message #870947] Thu, 10 May 2012 06:30 Go to previous messageGo to next message
Hi I do not understand your question: the method that's called
depends from the place you press crtl space
Re: Custom content Assist [message #870964 is a reply to message #870949] Thu, 10 May 2012 07:19 Go to previous messageGo to next message
Ah oki very good !
effectively it work...
the method created a new item
for the cross reference (i see now) icon's is by default
Re: Custom content Assist [message #871049 is a reply to message #870256] Thu, 10 May 2012 12:27 Go to previous message
thanks Christian
my problem is solved with a label provider
in fact I forgot to put the methods to enumName
I did it for enumDelc...
[Updated on: Thu, 10 May 2012 12:27] by Moderator
Previous Topic:dynamic template proposals in Xtext
Next Topic:One plugin muliple project
Current Time: Sat Jul 26 03:21:24 EDT 2025
Powered by FUDForum. Page generated in 0.11503 seconds
