Home » Modeling » QVT-OML » [QVTo] UML 2 UML transform
[QVTo] UML 2 UML transform [message #870050] Sat, 05 May 2012 23:14 Go to next message
I followed with success a tutorial with QVTo. But my objectives is UML
to UML transformation with UML Profiles. I saw previous messages on
Profiles, so I will get there eventually and get back to these.
Meanwhile, the tutorial I used is transforming models produces with
Ecore files From observation of a Papyrus XMI file, the models looks
similar, but I am blocking on a first issues and I cannot find the
solution in the past M2M messages. By the way, Google has a hard time
with the eclipse forum references, I can rely on the Google cache, but
is this a temporary problem ?
Back to my issue, I have
modeltype umlMM uses 'http://www.eclipse.org/uml2/3.0.0/UML';
transformation CIMTransformation(in umlIn : umlMM, out umlOut : umlMM);
main() {
-- umlIn.rootObjects()[umlIn::Package] -> map ...
Q1 - Going to [Operational QVT Project] > [Properties] > [QVT Settings]
> [Metamodel mappings], I cannot find the way of adding a local
reference to the uml metamodel. How can I ?
Q2 - I guess this problem is related to Q1. I do not get Completion in
(Ctrl-space) the transformation file ?
Q3 - Will I have to convert in some way the uml model file (produced
with Papyrus) with a conform ecore file, or it is a valid ecore
file ?
I can read the model with the sample Ecore editor, but I do not
want to assume it is valid.
Regards.
Re: [QVTo] UML 2 UML transform [message #870077 is a reply to message #870050] Sun, 06 May 2012 04:02 Go to previous messageGo to next message
Hi Alain,
the metamodel has to be registered. So install the UML2 package for eclipse. You do not need to add a metamodel mapping. Then you have code completion.
Tex
Re: [QVTo] UML 2 UML transform [message #870115 is a reply to message #870077] Sun, 06 May 2012 13:02 Go to previous messageGo to next message
Hi Tex Iano
Hm, I must be in the wrong menu settings...
Can you indicate me a page from the web, where I can follow
the procedure to do so, or the menu you are talking about ?
Are you refering to the menu listed in my question Q1 ?
Every attempts to insert different flavor of platform:...
failed. What kind of entries should I insert in the
Metamodel mappings source and target uri fields ?
I presume it is already there, since I have Papyrus (UML Modeler)
and QVTo installed. I did though, since you mentionned it installed
the 2 following packages:
+ EMF Compare UML2 Integration
+ UML2 Extender SDK
From Help>Install new software, I cannot find anything else related to
UML2. From the Eclipse Plug-ins list, I seem to have all UML2 related
software, UML2 Model Search Ui, UML2 UML Editor, ...
Still, cannot have any completion (and this indicate me I did not
configured my project correctly) !
Any other hints ?
Thanks in advance.
Re: [QVTo] UML 2 UML transform [message #870119 is a reply to message #870077] Sun, 06 May 2012 13:26 Go to previous messageGo to next message
Hello again Tex,
Now from your previous post, I have the following snippet:
modeltype uml "strict" uses uml('http://www.eclipse.org/uml2/3.0.0/UML');
transformation CIMTransformation(in umlIn : uml, out umlOut : uml);
main() {
umlIn.rootObjects()[umlIn::Package] -> map PackageToPackage();
Now I have the code completion for the umlIn::... but, should
I get a code completion for the qvt transformation fonctions like
PackageToPackage() ?
Re: [QVTo] UML 2 UML transform [message #870147 is a reply to message #870119] Sun, 06 May 2012 23:53 Go to previous messageGo to next message
Alain Lavoie a écrit :
> Hello again Tex,
> main() {
> Thanks
As an add-on to this discussion, from the wiki.eclipse.org/MDT/OCL/FAQ,
I get that ecore is a standalone metamodel that can define itself, and
that ecore can be used to express a UML metamodel. Furthermore, it
seems that UML is already delivered with QVTo. Hm... I still do not get
where the java PackageToPackage method is being defined. I verified
that that ecore::EPackage exist, both should use this definition for
my uml to uml transformation ?
Therefore, what is the equivalent PackageToPackage() in the ecore world ?
Finally, if I rely on ecore mm, I can imagine that I will miss some uml
concepts along the way, that those defined in uml but not in ecore.
Am I right ?
Regards.
Re: [QVTo] UML 2 UML transform [message #870159 is a reply to message #870147] Mon, 07 May 2012 01:28 Go to previous messageGo to next message
Your multiple messages seem to be getting increasingly confused.
I suggest a little more thought before pressing the send button,
otherwise I may start treating your messages as spam.
PackageToPackage is of course a mapping between two classes, so if you
use some other metamodel the parameter types will change.
Ecore corresponds to EMOF which is a simplified form of UML. If you
don't like the simplifications don't simplify.
An EMF mapping might be called EPackageToEPackage.
Ed Willink
>> Hello again Tex,
>> main() {
>> Thanks
> Am I right ?
> Regards.
Re: [QVTo] UML 2 UML transform [message #870255 is a reply to message #870159] Mon, 07 May 2012 09:22 Go to previous message
Ed Willink a écrit :
> Hi
Being alone on a project without any expertise around is a challenge.
I will respect your request.
Previous Topic:Code Completion / Operations in QVT installation
Next Topic:Failed to resolve metamodel when debugging
Current Time: Wed Jul 23 23:07:11 EDT 2025
Powered by FUDForum. Page generated in 0.19384 seconds
