Home » Language IDEs » C / C++ IDE (CDT) » Problem reading text file using argc and argv
Problem reading text file using argc and argv [message #869721] |
Thu, 03 May 2012 23:14  |
Hi there, before I'm getting bashed for posting this thread, I'm just saying that I can't find the any thread that is relevant to my problem :/ (either that or I'm using wrong keywords)
So, on to the problem:
Normally, I write something like this to run my C program and reading my input file "something.exe < textfile" and I'm using argc and argv in my main function.
The problem is, I don't know how to do this in Eclipse CDT.
I tried following a tips such as going to the Project Properties -> Run/Debug Settings -> "something.exe" -> Arguments and fill in the Program Arguments field. I tried writing "< textfile" (without quote) but my file is still not read!
So, I'm quite sure that I'm writing this incorrectly or I need to use the "Variables" button, but which option should I choose?
PS: I'm sort of new to programming in Eclipse, so please bear with me... Thanks! (Also, sorry if I double posted, since I didn't see any confirmation message after I pressed create topic button)
Re: Problem reading text file using argc and argv [message #869948 is a reply to message #869774] |
Fri, 04 May 2012 23:12   |
I'm on Windows, but I usually do this on UNIX's terminal, and that's what I wrote.
Btw, it didn't work, isn't this just the same as the suggested idea I did in my post?
Hmm... Would posting some of the code here helps? It's just a workshop exercise from my class, so I'm sure it's safe to post here.
#include <stdio.h>
int main(int argc, char *argv[])
void *gp;
gp = make_empty();
read_input(argc,argv,gp);
// There are some printf's here, but it's a function so I don't need to write it here
int read_input(int argc, char *argv[], void *gp)
char s[MAXSTR];
int i,j,w;
int n;
if(argc != NARGS){
fprintf(stderr,"There should be %d argument(s) to the %s"
" program.\n", NARGS, argv[0]);
return FALSE;
// determine size of graph
fgets(s,MAXSTR-1,stdin); // safer than gets()
while(s[0] == '#'){
// comment line
sscanf(s,"%d",&n);
set_size(gp,n);
// determine whether graph is directed
while(s[0] == '#'){
// comment line
if(s[0] == 'u'){
set_directed(gp,FALSE);
} else {
set_directed(gp,TRUE);
// read in graph itself
while(fgets(s,MAXSTR-1,stdin) != NULL){ // read in each line
if(s[0] == '#'){
continue; // comment line
sscanf(s,"%d %d %d",&i,&j,&w); // scan node numbers and
// the weight of edge
insert(gp,i,j,w);
return TRUE;
So... Yeah, on UNIX server, if i type "something.exe < testfile", it actually works, as opposed to "something.exe testfile" which actually gives me error :/
Sorry for the huge chunk of code! But basically from my main function, it will go to read_input function directly
Re: Problem reading text file using argc and argv [message #869950 is a reply to message #869948] |
Fri, 04 May 2012 23:59   |
> what I wrote.
> did in my post?
> Quote:
>> #include <stdio.h>
>> void *gp;
>> gp = make_empty();
>> to write it here
> Quote:
>> char s[MAXSTR];
>> int i,j,w;
>> int n;
>> if(argc != NARGS){
>> return FALSE;
>> while(s[0] == '#'){
>> // comment line
>> sscanf(s,"%d",&n);
>> set_size(gp,n);
>> while(s[0] == '#'){
>> // comment line
>> if(s[0] == 'u'){
>> } else {
>> if(s[0] == '#'){
>> insert(gp,i,j,w);
>> return TRUE;
> gives me error :/
You may want to spend some time studying I/O redirection, standard
input, output, and error. The < textfile format is redirecting the
standard input stream to be read from textfile. Including testfile as
an argument is something completely different.
You can redirect input/output on the Common tab of the Launch
Configuration for your program if you need to.
Re: Problem reading text file using argc and argv [message #869988 is a reply to message #869950] |
Sat, 05 May 2012 10:45  |
Ahh! Okay, now I know the term. Yeah, basically what I want is to redirect my input to my testfile somehow.
I tried going to that Common tab you suggested, but I can't seem to find anything related to redirecting input. If there's anything being redirected, it's the output instead! I tried linking my file to the "File:" field, but the output is written there, instead of being read.
Or am I opening the wrong option...?
If not, how do I do that? Sorry, I'll try to keep up with learning about those things, but I'm getting crammed with my other uni assignments :/
Attachment: 1.png
(Size: 87.24KB, Downloaded 6173 times)
[Updated on: Sat, 05 May 2012 10:46] by Moderator
Current Time: Mon Jul 21 02:39:23 EDT 2025
Powered by FUDForum. Page generated in 0.26843 seconds
