Home » Modeling » OCL » RoyalandLoyal example
RoyalandLoyal example [message #868788] Wed, 02 May 2012 10:42 Go to next message
In the RoyalandLoyal example, there is RoyalandLoyal.ocl file. I just want to know what tools or button/menu I should use to generate my xx.ocl file to validate the ecore model.
Thanks sincerely!
Re: RoyalandLoyal example [message #868833 is a reply to message #868788] Wed, 02 May 2012 11:53 Go to previous messageGo to next message
If you've installed the OCL Examples and Editors, you just do New File
something.ocl and it will use the Complete OCL editor.
To use it for validation, use the Load Complete OCL REesource menu
option (Juno M6 onwards) to load it into your modeling tool. Prior to
Juno M6 you must write some Java.
Ed Willink
> Thanks sincerely!
Re: RoyalandLoyal example [message #869743 is a reply to message #868833] Fri, 04 May 2012 03:24 Go to previous messageGo to next message
Is the OCL expression should be embedded into the xx.ecore file opened with xtext. In this way, the constraints will be validated. But how can we use the xx.ocl file to validate our ecore model?
Thanks for your reply.
Re: RoyalandLoyal example [message #869816 is a reply to message #869743] Fri, 04 May 2012 07:58 Go to previous messageGo to next message
My previous replay contained the answer.
"To use it for validation, use the Load Complete OCL REesource menu
Juno M6 you must write some Java. "
Ed Willink
Re: RoyalandLoyal example [message #869881 is a reply to message #869816] Fri, 04 May 2012 11:50 Go to previous messageGo to next message
It seems that I need an OCL compile. But I think I have installed it by installing OCL examples and editors, and OCL END USER SDK. Is it right?
Re: RoyalandLoyal example [message #869907 is a reply to message #869881] Fri, 04 May 2012 13:58 Go to previous messageGo to next message
There is no OCL compiler. OCL execution is interpreted.
[Juno introduces an OCL to Java capability within genmodel, so that you
can then use the Java compiler for improved speed.]
If you have installed the Juno M6 OCL Examples and Editors, without
error, then you have everything necessary.
Ed Willink
> right?
Re: RoyalandLoyal example [message #869956 is a reply to message #869907] Sat, 05 May 2012 02:39 Go to previous messageGo to next message
The following shows the code example how we can parse xx.ocl file. I think it just you suggested me before to write some java prior.
I want to modify the codes in the ocl document guide. But some words puzzled. The notation denotes that "get an OCL text file via some hypothetical API", I just wonder what API should I use. Can you give some reference?
The eclipse reminds me to create getWorkspaceFile class. If there is any code already I can use?
OCL<?, EClassifier, ?, ?, ?, ?, ?, ?, ?, Constraint, EClass, EObject> ocl;
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
// get an OCL text file via some hypothetical API
IFile file = getWorkspaceFile("/ocl/constraints.ocl");
InputStream in = file.getContents();
Map<String, Constraint> constraintMap = new HashMap<String, Constraint>();
// parse the contents as an OCL document
try {
OCLInput document = new OCLInput(in, file.getCharset());
List<Constraint> constraints = ocl.parse(input);
for (Constraint next : constraints) {
constraintMap.put(next.getName(), next);
OCLExpression<EClassifier> body = next.getSpecification().getBodyExpression();
System.out.printf("%s: %s%n", next.getName(), body);
} finally {
in.close();
[Updated on: Sat, 05 May 2012 02:42] by Moderator
Re: RoyalandLoyal example [message #872842 is a reply to message #869956] Wed, 16 May 2012 19:34 Go to previous messageGo to next message
I would also like to know about it. Where I have to go to install the Juno M6 OCL Examples and Editors and also wonder if when creating the file xx.ocl and create restrictions on even if you need to integrate this file xx.ocl to my Ecore Metamodel and if so how?
Thank's.
[Updated on: Wed, 16 May 2012 19:35] by Moderator
Re: RoyalandLoyal example [message #873179 is a reply to message #872842] Thu, 17 May 2012 12:25 Go to previous messageGo to next message
What is a "wing"?
See my other answer.
Ed Willink
> wing and also wonder if when creating the file xx.ocl and create
> Thank's.
Re: RoyalandLoyal example [message #874859 is a reply to message #872842] Mon, 21 May 2012 13:31 Go to previous messageGo to next message
I'm sorry. I was wrong.
Wing isn't nothing.
I edited my post. look:
Pablo Silva wrote on Wed, 16 May 2012 19:34
Thank's.
I even don't understand how to integrate my Ecore and my xx.ocl file.
If you can explain to me, I appreciate.
Thank's
Re: RoyalandLoyal example [message #874903 is a reply to message #874859] Mon, 21 May 2012 15:01 Go to previous messageGo to next message
Try following the OCLinEcore tutorial.
Ed Willink
> Wing isn't nothing.
>> Thank's.
> Thank's
Re: RoyalandLoyal example [message #875960 is a reply to message #874903] Wed, 23 May 2012 12:13 Go to previous message
Thank's for the help!
Previous Topic:[Announce] Eclipse OCL 4.0.0 (Juno) RC1 is now available
Next Topic:OCL as an "object reference graph"
Current Time: Fri Jul 25 20:04:25 EDT 2025
Powered by FUDForum. Page generated in 0.05769 seconds
