Home » Eclipse Projects » Virgo » Could not use repository chain in new virgo tool
Could not use repository chain in new virgo tool [message #869725] Thu, 03 May 2012 23:56 Go to next message
ext.type=external
ext.searchPattern=repository/ext/{artifact}
usr.type=watched
usr.watchDirectory=repository/usr
test-app.type=external
test-app.searchPattern=E:/BGLPro/researches/osgi/test_v1/*/${bundle}
chain=ext,usr,test-app
the above is the repository configuration, I set these and click the refresh button in repository tag panel, but useless.
Re: Could not use repository chain in new virgo tool [message #869726 is a reply to message #869725] Fri, 04 May 2012 00:00 Go to previous messageGo to next message
George, please file a bug on this indicating what steps you took and whether this worked with prior versions of tooling.
Re: Could not use repository chain in new virgo tool [message #869729 is a reply to message #869726] Fri, 04 May 2012 00:51 Go to previous messageGo to next message
Hi miles,
The steps are simple,
1. config the repository file
2. go to IDE and click the refresh button on the repository tag panel of virgo server instance. And then can see the change from the settings.
It worked before, but no more success during the last update yesterday.(It's totally crashed, and today I update again, not working now)
The IDE log file has no error for this.
[Updated on: Fri, 04 May 2012 00:54] by Moderator
Re: Could not use repository chain in new virgo tool [message #869872 is a reply to message #869729] Fri, 04 May 2012 11:25 Go to previous messageGo to next message
OK, I'll still want a bug. Smile
Re: Could not use repository chain in new virgo tool [message #869896 is a reply to message #869872] Fri, 04 May 2012 12:53 Go to previous messageGo to next message
OK, I've created one myself. Smile See 378520: Search repository panel broken
https://bugs.eclipse.org/bugs/show_bug.cgi?id=378520.
But please note that it's an important part of Eclipse community process to have users entering bugs. I want to encourage everyone to do that when they have identified a repeatable issue. See http://wiki.eclipse.org/Bug_Reporting_FAQ for more details.
Re: Could not use repository chain in new virgo tool [message #869900 is a reply to message #869896] Fri, 04 May 2012 13:05 Go to previous messageGo to next message
The issue has been resolved. The build itself should complete and promote to snapshot in the next 15 minutes or so.
Re: Could not use repository chain in new virgo tool [message #870172 is a reply to message #869900] Mon, 07 May 2012 03:03 Go to previous message
Thanks very much!
It was my mistake anyway.
It should be set as
test-app.searchPattern=E:/BGLPro/researches/osgi/test_v1/*/{bundle}
but I was set it as
so bad Very Happy
Previous Topic:How to get EclipseRT/Virgo option back in New Server wizard (STS 2.9.1)
Next Topic:Conflicts configuring EclipseLink with Virgo
Current Time: Thu Jul 24 21:40:46 EDT 2025
Powered by FUDForum. Page generated in 1.31933 seconds
