Home » Archived » BIRT » BIRT 3.7.2: Unable to access the data from outer data set using row._outer<column-name>(Unable to access the data from outer data set using row._outer<column-name>)
BIRT 3.7.2: Unable to access the data from outer data set using row._outer<column-name> [message #858786] Fri, 27 April 2012 05:47 Go to next message
We are currently migrating to BIRT 3.7.2 from BIRT 2.3. We are facing one common issue with all report designs. Wherever we have a enclosed grid/table referring to a data set bound to an enclosing list, it gived an error saying:
Invalid bound column name: <column-name>.
In all such places we have referred to outer data set column using "row._outer".
Another important fact is that when we used BIRT 3.7 the reports were migrated easily without making any changes.
Any insights would be of great help here!
[Updated on: Fri, 27 April 2012 05:48] by Moderator
Re: BIRT 3.7.2: Unable to access the data from outer data set using row._outer&lt;column-name&am [message #859932 is a reply to message #858786] Fri, 27 April 2012 17:47 Go to previous messageGo to next message
Can you post one of the examples?
Jason
> an error saying:
> "row._outer".
Re: BIRT 3.7.2: Unable to access the data from outer data set using row._outer&lt;column-name&am [message #869801 is a reply to message #859932] Fri, 04 May 2012 06:57 Go to previous messageGo to next message
Apologies for late response, as we were facing an out of memory issue with 3.7.2 eclipse while testing it.
I have attached the sample report design.
Re: BIRT 3.7.2: Unable to access the data from outer data set using row._outer&amp;lt;column-nam [message #869879 is a reply to message #869801] Fri, 04 May 2012 11:45 Go to previous messageGo to next message
Nitesh,
Can you open a bugzilla entry with your example report?
Jason
Re: BIRT 3.7.2: Unable to access the data from outer data set using row._outer&amp;lt;column-nam [message #870153 is a reply to message #869879] Mon, 07 May 2012 00:59 Go to previous messageGo to next message
Created a Bugzilla entry Bug 377905. I have also uploaded the sample report design.
Re: BIRT 3.7.2: Unable to access the data from outer data set using row._outer&amp;amp;lt;column [message #870322 is a reply to message #870153] Mon, 07 May 2012 12:05 Go to previous message
Thanks for posting the bug number.
Jason
> report design.
Previous Topic:javascript to iterate through a dataset to find a value?
Next Topic:BIRT and MSSQL: No suitable driver found for jdbc:
Current Time: Wed Jul 30 13:33:17 EDT 2025
Powered by FUDForum. Page generated in 0.44617 seconds
