bar chart with literal array for Category (x) series? [message #868859] |
Wed, 02 May 2012 12:34  |
I'm new to BIRT and wondering if I can create a bar graph using Category information that's not present in my Data? Can I set the expression to something like {"Vanilla", "Chocolate", "Strawberry"} instead of grabbing it from a data source?
Basically, my data source is a flat file from some survey software. The columns don't seem to work well for what I thought would be a pretty simple chart, and I have no way to alter the csv files. What I have is something like this:
Vanilla Chocolate Strawberry
yes no yes
yes no no
no yes no
yes yes yes
I need to make a bar chart showing the total count of each flavor. There is no column listing the flavors, though. I've tried every variation I can think of to add them as constants, like I showed above, but nothing has worked. I've tried adding them through a script when the chart is rendered, but for some reason I get a syntax error as soon as I try to define a new String[] array. The error points to the empty brackets as if it doesn't understand the array, am I forgetting to import a package?
thanks!
-sean
Re: bar chart with literal array for Category (x) series? [message #869673 is a reply to message #868859] |
Thu, 03 May 2012 12:29  |
Sean,
You can do this with script. Have a look at the attached example.
Jason
> yes no yes
> yes no no
> no yes no
> yes yes yes
> thanks!
> -sean
FUDForum. Page generated in 0.07598 seconds
