Home » Eclipse Projects » Virgo » Help! Update virgo tool from sts2.91 and the plugin crashed
Help! Update virgo tool from sts2.91 and the plugin crashed [message #869187] Wed, 02 May 2012 23:39 Go to next message
I am using virgo tool plugin and update it this morning(IDE tells me there is a new update), the new version 1.0.0.201205020006-SNAPSHOT. After install this new feature and restart the IDE, I found that the Bundle repository configuration tag of virgo server instance is missing. I try to reinstall a new virgo environment into IDE, but it could not work. My job is broke, please help!
The attachment is the IDE log.
  • Attachment: .log
    (Size: 90.54KB, Downloaded 226 times)
[Updated on: Wed, 02 May 2012 23:42] by Moderator
Re: Help! Update virgo tool from sts2.91 and the plugin crashed [message #869455 is a reply to message #869187] Thu, 03 May 2012 08:34 Go to previous messageGo to next message
I downloaded the latest version of indigo, and could install the newest version of virgo tool.
Then I configured the runtime configuration, and create a new instance virgo server into servers panel.
I double clicked the instance server and the configuration page showed up. I selected the Repository tag, and saw the right area of it(the repository list) is empty.
Then I closed the IDE, and restarted it again, it crashed as the sts2.91 acts.
I test this install a couple of times in new Indigo IDE and the problem is the same as I mentioned.
Hope to fix it as soon as possible...
Re: Help! Update virgo tool from sts2.91 and the plugin crashed [message #869577 is a reply to message #869455] Thu, 03 May 2012 12:13 Go to previous messageGo to next message
Hi George,
Sorry you're having trouble. This is the downside of working off of a snapshot build. If you don't have any need for 3.5.0 support you could try the milestone. We hope to have an M4 build out real soon, perhaps today. In the meantime, I've just spun off a new build that will probably address your issue (it's a dependency change) so you might want to try a new update in an hour or so.
cheers,
Miles
Re: Help! Update virgo tool from sts2.91 and the plugin crashed [message #869723 is a reply to message #869577] Thu, 03 May 2012 23:42 Go to previous messageGo to next message
The new version is ok now, thanks for helping Laughing
Re: Help! Update virgo tool from sts2.91 and the plugin crashed [message #869724 is a reply to message #869723] Thu, 03 May 2012 23:44 Go to previous message
Yeah! Very Happy (And we'll have that official M4 release RSN.)
Previous Topic:Dependent Applications
Next Topic:How to compensate for slow provisioning server
Current Time: Sun Jul 27 04:07:54 EDT 2025
Powered by FUDForum. Page generated in 0.06048 seconds
