Home » Eclipse Projects » Remote Application Platform (RAP) » Image
Image [message #86749] Mon, 12 May 2008 01:16 Go to next message
I want to know how can i create an image from my Image Data or from my
input stream, because am using Jfree Chart lib,,,and there is no bridge
between SWTand AWT in RAP "for example SWT_AWT.new_Frame(this)". So, am
trying to write the image to a buffer using AWT, and then load it from the
same buffer using SWT.
RWT Image class dosn't provide a constractor to recieve an image data , or
even an input stream, which makes it diffecult to regenerate the image.
Another Question here , Some of Jfree Library APIs are using Swing,So is
RAP supporting Swing?.
thankx
Salwa
Re: Image [message #86867 is a reply to message #86749] Mon, 12 May 2008 06:37 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
you may use Graphics#getImage(String,InputStream) for creating an image
based on an input stream.
RAP doesn't support Swing. In theory this could be possible, but the
effort to do so is currently out of the project's scope.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Salwa [mailto:salwa.moh@gmail.com]
Bereitgestellt: Montag, 12. Mai 2008 07:17
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Image
Betreff: Image
the same buffer using SWT.
or even an input stream, which makes it diffecult to regenerate the
image.
thankx
Salwa
Re: Image [message #86881 is a reply to message #86867] Mon, 12 May 2008 08:02 Go to previous messageGo to next message
Hi Frank
Is that mean I can't get JFree library work till I do the integration
between RAP and Jfree , and replace swing dependancy with swt and Jfaces ?
Thankx
Salwa
Charts in RAP (was Re: Image) [message #86896 is a reply to message #86881] Mon, 12 May 2008 08:37 Go to previous messageGo to next message
Originally posted by: evolanakis.innoopract.com
Hi Salwa,
I see two possibilities:
- as mentioned in a previous thread, if you can use JFree on the server
to save the chart into an image file, you should be able to show the
image in RAP. For example you can write a servlet that returns an image.
- second, you could look into the google chart API. For example this
shows a pie chart:
http://chart.apis.google.com/chart?chs=250x100&chd=t:60, 40&cht=p3&chl=Hello|World
This works great in the browser (but may be problematic if you have an
offline RCP client). The drawback is that you send the chart data over
unsecured http, so it could be a problem if your data is confidential.
There is small POJO Java wrapper that does not have any dependencies here:
http://code.google.com/p/gchartjava/
GChartJava example:
Slice slice1 = new Slice(33,"foo");
Slice slice2 = new Slice(33,"bar");
Slice slice3 = new Slice(34,"zap");
PieChart chart = new PieChart(slice1, slice2, slice3);
String url = chart.createURLString();
You can then use the URL to show the chart.
If you want a very polished solution, you could write a custom widget
around this, but I'm sure there other options too.
Elias.
Salwa wrote:
> Hi Frank
> Thankx Salwa
Re: Charts in RAP (was Re: Image) [message #87168 is a reply to message #86896] Wed, 14 May 2008 08:26 Go to previous messageGo to next message
thankx Elias,
I know now how to create a servlet to generate A JFreeChart , but I wanted
to know how can I use servlet on my RAP application. Actually The servlet
result should be shown in a browser within my RAP Application. How can I
do that.
am using equinox.Jetty as a webserver.
Salwa
Re: Image [message #87255 is a reply to message #87168] Wed, 14 May 2008 10:34 Go to previous messageGo to next message
maybe I don't understand the problem. But if you have a servlet that
produces the JFreeChart, why don't you use the browser widget and set
the URL of the browser widget to the servlet (browser.setURL(
"myApp/myServlet?chart=0815"))? If the servlet is mapped like this:
<extension point="org.eclipse.equinox.http.registry.servlets">
<servlet
alias="/myServlet"
class="org.mycompany.myproject.MyServlet"
httpcontextId="org.eclipse.rap.httpcontext"
load-on-startup="true">
</servlet>
</extension>
Ciao
Frank
Bereitgestellt: Mittwoch, 14. Mai 2008 14:27
Unterhaltung: Image
Betreff: Re: Charts in RAP (was Re: Image)
thankx Elias,
wanted to know how can I use servlet on my RAP application. Actually The
servlet result should be shown in a browser within my RAP Application.
How can I do that.
Salwa
Re: Image [message #87367 is a reply to message #87255] Wed, 14 May 2008 17:21 Go to previous messageGo to next message
Thankx Alot Frank
I have added the extension with http ,, to register my servlet class, but
i didn't get a result on my browser ,,and am sure because of the URL.
my URL is look like this:
http://192.168.1.12:7070/Salwa/SarvletClassName
where Salwa is my RAP application alias name and SarvletClassName is my
servlet alias name.
Could you please explain your URL
"browser.setURL("myApp/myServlet?chart=0815"))? " , because I didn't get
what you mean by "myApp" and "chart=0815"
Salwa
Re: Image [message #87382 is a reply to message #87367] Thu, 15 May 2008 01:08 Go to previous messageGo to next message
Hm,
somehow it truncated the explanation, which was already there. But
anyway, are you running your app currently from the Eclipse IDE? Meaning
your app URL would look s.th. like this:
http://192.168.1.12:7070/rap?startup=myentrypoint. Running the same app
(let's say it's called myapp) on a tomcat for example the URL would look
like this: http://192.168.1.12:7070/myapp/rap?startup=myentrypoint. So
running from the IDE access to your servlet should look like this:
http://192.168.1.12:7070/myServletName, where myServletName is the
servlet alias name mapped in the extension-point. On tomcat it should
look like this: http://192.168.1.12:7070/myapp/myServletName.
Ciao
Frank
Bereitgestellt: Mittwoch, 14. Mai 2008 23:22
Unterhaltung: Image
Betreff: Re: Image
Thankx Alot Frank
but i didn't get a result on my browser ,,and am sure because of the
URL.
servlet alias name.
Salwa
Re: Image [message #87528 is a reply to message #87382] Thu, 15 May 2008 09:29 Go to previous messageGo to next message
Thankx Very much Frank and Elias , JFreeChart is working fine with me now
Salwa
Re: Image [message #90131 is a reply to message #87528] Mon, 26 May 2008 17:14 Go to previous message
Originally posted by: tavoaqp.gmail.com
Hi Salma
How could I pass data to this servlet in order to generate dynamic graphs?
thanks
Gustavo
Salwa escreveu:
> now ..
> Regards Salwa
Previous Topic:Ressources
Next Topic:Tree really slow in IE7
Current Time: Sun Aug 31 01:06:22 EDT 2025
Powered by FUDForum. Page generated in 0.05120 seconds
