Home » Eclipse Projects » GEF » can GEF logic example (plugin or standalone) integrate with RCP plugin?
can GEF logic example (plugin or standalone) integrate with RCP plugin? [message #868771] Wed, 02 May 2012 10:14 Go to next message
Hi there,
I need to integrate the GEF logic example to a RCP plugin. How can i do that?
I cannot download it from pserver, that gives a proxy error. Is there any way to resolve this issue?
Then I copied the example available with SDK and opened in eclipse. I can run the standalone logic application, but cannot run the logic plugin. which is asking user name and password. I gave it anonymous user, but does not work. Is there any way to run this logic plugin?
Thanks in advance !
K
Re: can GEF logic example (plugin or standalone) integrate with RCP plugin? [message #885040 is a reply to message #868771] Tue, 12 June 2012 06:32 Go to previous message
In Eclipse Go To Show View -->Plugins --> org.eclipse.gef.examples.logic -->Import as Project from repository.It will ask for Login and password.
Give anonymous in place of login.Let the password as it is.Finish.
Project would be imported in your Project Explorer.
You can add it as your dependency Plugin in you RCP Application.
Previous Topic:Two OutLine Trees
Next Topic:max width for GEF Editor
Current Time: Sat Jul 26 23:27:30 EDT 2025
Powered by FUDForum. Page generated in 0.03903 seconds
