Home » General (non-technical) » Jobs and employment » Sr Developer (ETL) - Java/C++, Permanent, Dallas, TX
Sr Developer (ETL) - Java/C++, Permanent, Dallas, TX [message #855528] |
Tue, 24 April 2012 18:40  |
This position will be part of the senior developer group in a team of approx. 7 developers ranging from Junior to Senior/Lead developers, to develop a custom ETL product set that targets extremely large volume Tier 1 level data warehousing using a highly scalable clustered solution. The product set is to be developed against an initial tier 1 data warehouse and then expanded to a global product set with long term support and evolution adapting to changing product requirements.
Responsibilities will include
• Primary developer in one of 4 distinct development streams of an end to end custom ETL solution for the OPTIMA platform that is highly scalable, configurable and structurally aware
• Align to overall development and integration strategy for the product set
• Work within a structured and source controlled IDE environment (Eclipse with SVN)
• Allocation of QA and testing to junior developers
• Supporting the Technical team lead in the allocation and review of deployment and QA tasks across the team
• Design input and consumption of the targeted metadata model (MDM, the configuration model) for the overall solution and the consistent use of the MDM to integrate with the remaining 3 development streams
Development requirements
• Large volume data management
• Highly configurable by MDM
• Efficient dataset management in memory with manual memory clean up and management
• Vast experience in multithreading with intelligent handovers
• High performance ODBC data connectors
• MDM configurable high performance file management on Solaris based OS with database assisted logging/detailed tracking
• In depth understanding of physical and logical data modelling concepts in large data warehousing with transactional level data availability requirements
• Extensive experienced in SQL (ANSI)
• Unix shell scripting experience would be beneficial
Software/Technologies
• Eclipse IDE on Windows
• Java, C++
• Teradata TPT load method interface and ODBC load interface in C++
• Subversion source control implementation on Eclipse
• Development to target high performance clustered Solaris 10 (+) environment
• Advantage to candidates with experience in Unix shell scripting, perl scripting
• Solaris OS administration experience beneficial
Applicants can contact at roland.theron@aircominternational.com
[Updated on: Fri, 04 May 2012 17:43] by Moderator
Re: Sr Developer (ETL) - Java/C++, Permanent, Dallas, TX [message #857671 is a reply to message #855528] |
Thu, 26 April 2012 15:02   |
I am interested in this position. how do I apply?
--Gautam
http://fast-code.sourceforge.net/
On 4/24/2012 5:40 PM, Roland Theron wrote:
> This candidate will be part of the senior developer group in a team of
> (Eclipse with SVN)
> management
> with database assisted logging/detailed tracking • In depth
> • Java, C++ • Teradata TPT load method interface and ODBC load interface
> in C++
> environment
> scripting
> Applicants can contact me via direct message on this forum
Re: Sr Developer (ETL) - Java/C++, Permanent, Dallas, TX [message #866315 is a reply to message #858639] |
Mon, 30 April 2012 16:56   |
I'm not sure how to send direct reply.
Would you contact me through my project?
--Gautam
On 4/27/2012 3:20 AM, Roland Theron wrote:
> As per the original post you can contact me via direct message on this
> forum, I'll provide contact details there
> Gautam wrote on Thu, 26 April 2012 15:02
>> Hi,
>> Thanks,
>> --Gautam
Current Time: Wed Jul 23 04:17:37 EDT 2025
Powered by FUDForum. Page generated in 0.08444 seconds
