Home » Archived » EGL Development Tools » IBM i program call limitations maximum of 35 parameters(IBM i program call limitations maximum of 35 parameters)
IBM i program call limitations maximum of 35 parameters [message #867546] Tue, 01 May 2012 06:58 Go to next message
http: //publib.boulder.ibm.com/infocenter/iadthelp/v7r1/index.jsp?topic=/com.ibm.etools.iseries.javatools.doc/topics/t5call2.html
Program call bean limitations
Program call definitions that invoke a program can have a maximum of 35 parameters.
Program call definitions that invoke a procedure in a service program can have a maximum of 7 parameters
Are there any other way
Egon
Re: IBM i program call limitations maximum of 35 parameters [message #868399 is a reply to message #867546] Tue, 01 May 2012 18:20 Go to previous messageGo to next message
That is indeed a Toolbox limitation...
One workaround is to use a data structure as a parameter.
For example, on the RPG side, here's a program with one entry parameter consisting of a data structure containing 40 subfields:
D MyRPG           PR                  ExtPgm('MYRPG')
D  parmDS1                            LikeDS(DS1)
D DS1             DS                  qualified
D  parm1                         2
D  parm2                         2
D  parm3                         2
D  parm4                         2
D  parm5                         2
D  parm6                         2
D  parm7                         2
D  parm8                         2
D  parm9                         2
D  parm10                        2
D  parm11                        2
D  parm12                        2
D  parm13                        2
D  parm14                        2
D  parm15                        2
D  parm16                        2
D  parm17                        2
D  parm18                        2
D  parm19                        2
D  parm20                        2
D  parm21                        2
D  parm22                        2
D  parm23                        2
D  parm24                        2
D  parm25                        2
D  parm26                        2
D  parm27                        2
D  parm28                        2
D  parm29                        2
D  parm30                        2
D  parm31                        2
D  parm32                        2
D  parm33                        2
D  parm34                        2
D  parm35                        2
D  parm36                        2
D  parm37                        2
D  parm38                        2
D  parm39                        2
D  parm40                        2
D MyRPG           PI
 /free
  parmDS1.parm1  = ' 1';
  parmDS1.parm40 = '40';
  *inlr = *on;
 /end-free
You can use more than one data structure as parameters (up to the 35 parm limit), use any of the data types in your structures, use arrays and arrays of structures, etc.
--Dan
Re: IBM i program call limitations maximum of 35 parameters [message #868419 is a reply to message #867546] Tue, 01 May 2012 19:23 Go to previous message
You might also want to look into XMLService....it uses a completely different underlying mechanism for making program calls...
See:
http://www.ibmsystemsmag.com/ibmi/developer/rpg/EGL-and-XMLService--Hand,-Meet-Glove/
--Dan
Previous Topic:Debugger options
Next Topic:dojo-openlayers in EDT?
Current Time: Sun Aug 31 01:15:34 EDT 2025
Powered by FUDForum. Page generated in 0.05096 seconds
