Home » Modeling » TMF (Xtext) » EOF not matching RULE_EOL
EOF not matching RULE_EOL [message #865840] Mon, 30 April 2012 11:53 Go to next message
I'm having difficulties in understanding why I need an additional line at the end of my files with the attached grammar.
The message is "mismatched input <EOF> expecting RULE_EOL" but my EOL rule should accept both a new line or the EOF token...
Re: EOF not matching RULE_EOL [message #865948 is a reply to message #865840] Mon, 30 April 2012 13:00 Go to previous messageGo to next message
did you see the bunch of warning you get with your dsl:
Decision can match input such as "RULE_EOL" using multiple alternatives
if your EOL is allowed everywhere why dont you make it generally hidden
(and maybe make it visible explicitely where it is allowed only at certain places)
Re: EOF not matching RULE_EOL [message #866608 is a reply to message #865948] Mon, 30 April 2012 20:06 Go to previous messageGo to next message
On 2012-30-04 19:00, Christian Dietrich wrote:
> certain places)
+1 to that...
....or even allow it everywhere using hidden, and validate the few places
where it is not allowed as you can then have an error message that makes
sense "Newline not allowed here" and provide a quickfix to remove it.
The alternative is that users that enter a new line where they are not
supposed to will get syntax errors like "got EOL, expected xxx" which a
lot of the time is just gobbledygook to a user that is unaware of the
actual grammar rule/terminal names.
(it also makes your grammar cleaner and removes ambiguities).
- henrik
Re: EOF not matching RULE_EOL [message #867389 is a reply to message #866608] Tue, 01 May 2012 05:12 Go to previous messageGo to next message
I had it hidden but then I was having trouble in describing that an element is ended by a line, can you help me with it? I'm experiencing other problems as well, like I can't use Given, When, Then, And or But in any part of the file.
My current grammar and an example file are attached.
I will appreciate if you can help me with this.
Re: EOF not matching RULE_EOL [message #867685 is a reply to message #867389] Tue, 01 May 2012 08:22 Go to previous messageGo to next message
Without fully digging into the grammar and your sample input (I don't
have the time for that), here are a few things that I did notice...
You have:
terminal STEP_KEYWORD:
('Given' | 'When' | 'Then' | 'And' | 'But');
change that to just:
STEP_KEYWORD:
as you are using the quoted words as keywords in one place, but then you
squash all of the different words into the same token "STEP_KEYWORD" in
the terminal - so this:
type=('Given' | 'When' | 'Then' | 'And' | 'But') EOL*
will never work as the lexer would return the token STEP_KEYWORD.
If you really want it as a terminal, you could instead change it to:
type = STEP_KEYWORD EOL*
Looks like you may have an issue with single quoted string in WORD as it
clashes with STRING - which makes a'a' produce WORD and not WORD STRING
(but that may be what you want).
Regarding the EOL / EOF issues - I take back what I said earlier, now
that I seen the sample input - you really do need to have EOL as
something significant and can't in most cases hide it.
It seems the problems are mostly lexical, and trying to write good
lexing rules with the grammar can be difficult. If you continue to have
trouble it may be best to switch to an external lexer where you can do
more advanced things.
Hope that helps.
- henrik
Re: EOF not matching RULE_EOL [message #868041 is a reply to message #867685] Tue, 01 May 2012 12:05 Go to previous messageGo to next message
Hi Henrik,
it does help, but I'm sure I'm still missing something.
As you can see, in my grammar the keyword And has a specific meaning only after a Scenario: or Scenario Outline: token... I don't know why the lexer is recognizing it as a Step while it is expecting a Line.
Correct me if I'm wrong but the terminals should be recognized first and then used into the grammar.
This should mean that if I have a terminal for And and I use it somewhere else, the terminal get parsed first. In my grammar:
Feature:
	'Feature:' title=FeatureDescription EOL+
	description+=FeatureDescription* EOL*
	scenarios+=Scenario EOL*;
Scenario:
	'Scenario:' title=Line EOL*
	description+=Line* EOL*
	conditions+=Step+ EOL*;
Step:
	type=STEP_KEYWORD EOL*
	description=Line EOL*
Line:
	content=CharSequence EOL;
CharSequence:
	(STRING | WORD | INT | ANY_OTHER)+;
FeatureDescription:
	(CharSequence | STEP_KEYWORD)+;
terminal WORD:
	'^'? ('a'..'z' | 'A'..'Z' | '_' ) ('a'..'z' | 'A'..'Z' | '_' | '0'..'9' | "'" | "#" |
		('\\' ( 'u' | '"' | "'" | '\\'))
terminal INT returns ecore::EInt:
	('0'..'9')+;
terminal STRING:
	'"' ('\\' ('b' | 't' | 'n' | 'f' | 'r' | 'u' | '"' | "'" | '\\') | !('\\' | '"'))* '"' |
	"'" ('\\' ('b' | 't' | 'n' | 'f' | 'r' | 'u' | '"' | "'" | '\\') | !('\\' | "'"))* "'";
terminal SL_COMMENT:
	'#' !('\n' | '\r')* EOL;
terminal SPACE:
	(' ' | '\t')+;
terminal EOL:
	(('\r'? '\n') | EOF);
terminal ANY_OTHER:
Whenever I encounter And a STEP_KEYWORD token should be identified and if I'm parsing a Feature then it should be allowed as part of the feature description. In my case it get's identified as a step type, but at this point I can't have a step type as a Step can appear only inside a Scenario....
About the EOF, whenever an EOF is encountered it should get parsed into an EOL token and, as you can see, I've an EOL* at the end of a step and an EOL at the end of Line... If my logic makes sense I shouldn't need any CR/LF at the end of a Step description as the EOF should get captured by the Line EOL fulfilling the grammar requirement.
I don't understand why it seems requiring a CR/LF at the end of the file, may be this is related to the multiple (10 times) warnings I'm getting when compiling my grammar:
Decision can match input such as "RULE_EOL" using multiple alternatives: 1, 2
Sorry to bother you guys, but it seems I'm lost here.
Re: EOF not matching RULE_EOL [message #868150 is a reply to message #868041] Tue, 01 May 2012 13:11 Go to previous messageGo to next message
On 2012-01-05 18:05, rlogiacco@xxxxxxxx Lo Giacco wrote:
> Hi Henrik,
> then used into the grammar. This should mean that if I have a terminal
> my grammar:
In general I have found that you will run into trouble when keywords are
expressed as terminals.
The lexer parses a terminal, then checks if the parsed content is a
keyword, and if so, delivers the token for the keyword instead of the
parsed terminal. Hence my suggestion to change the "STEP_KEYWORD" rule
to be a parser rule instead of a terminal.
> Feature:
> Scenario:
> Step:
> type=STEP_KEYWORD EOL* description=Line EOL*
> Line:
> CharSequence:
> FeatureDescription:
> terminal WORD:
> ('0'..'9')+;
> terminal STRING:
> terminal SPACE:
> (' ' | '\t')+;
> terminal EOL:
> terminal ANY_OTHER:
> a Scenario....
Basically have two different rules; one that allows STEP_KEYWORDS and
treats them as non special, and one that does not include them as text).
I am not sure the EOF surfaces in the grammar the way you expect.
I would try to write a minimal grammar with a single terminal and see
what happens - if EOF is actually delivered and recognized by the
parser. If you do this as a minimal grammar, you should also be able to
debug the lexer and see exactly what happens.
> 1, 2
You have to fix those...
Re: EOF not matching RULE_EOL [message #868406 is a reply to message #868150] Tue, 01 May 2012 18:33 Go to previous message
Btw, have you looked at Jnario ?
Seems to be a parser for the same type of language.
- henrik
>> Hi Henrik,
>> my grammar:
>> Feature:
>> Scenario:
>> Step:
>> Line:
>> CharSequence:
>> FeatureDescription:
>> terminal WORD:
>> ('0'..'9')+;
>> terminal STRING:
>> terminal SPACE:
>> (' ' | '\t')+;
>> terminal EOL:
>> terminal ANY_OTHER:
>> a Scenario....
>> 1, 2
Previous Topic:Null pointer when serializing cross references
Next Topic:Confused about the map function
Current Time: Thu Jul 24 23:42:53 EDT 2025
Powered by FUDForum. Page generated in 0.07698 seconds
