Home » Language IDEs » Java Development Tools (JDT) » Eclipse Classic vs Eclipse Java
Re: Eclipse Classiv vs Eclipse Java [message #868396 is a reply to message #868387] |
Tue, 01 May 2012 18:11   |
Stephan Herrmann wrote on Tue, 01 May 2012 17:43Rudolf Schmidt wrote on Tue, 01 May 2012 20:50the resolving problem occurs in the file RenamePrivateFieldTests and not in the file RenameFieldProcessor. its the line number 35: "import org.eclipse.jdt.internal.corext.refactoring.rename.RenameFieldProcessor;" with the error message: "The import org.eclipse.jdt.internal.corext.refactoring.rename.RenameFieldProcessor cannot be resolved"
So, your org.eclipse.jdt.ui.tests.refactoring project cannot "see" your org.eclipse.jdt.ui. Maybe you need to check the versions in your MANIFEST.MF's. Aren't there any error markers on the manifest?
Stephan
Hey Stephan,
indeed, there are some errors. The MANIFEST.MF containing RenamePrivateFieldTests cants resolve the package "org.eclipse.test.performance"
thats the content of the manifest file:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %Plugin.name
Bundle-SymbolicName: org.eclipse.jdt.ui.tests.refactoring; singleton:=true
Bundle-Version: 3.8.0.qualifier
Bundle-ClassPath: refactoringtests.jar
Bundle-Activator: org.eclipse.jdt.ui.tests.refactoring.infra.RefactoringTestPlugin
Bundle-ActivationPolicy: lazy
Bundle-Vendor: %Plugin.providerName
Bundle-Localization: plugin
Export-Package:
org.eclipse.jdt.ui.tests.refactoring;x-internal:=true,
org.eclipse.jdt.ui.tests.refactoring.actions;x-internal:=true,
org.eclipse.jdt.ui.tests.refactoring.all;x-internal:=true,
org.eclipse.jdt.ui.tests.refactoring.ccp;x-internal:=true,
org.eclipse.jdt.ui.tests.refactoring.changes;x-internal:=true,
org.eclipse.jdt.ui.tests.refactoring.extensions;x-internal:=true,
org.eclipse.jdt.ui.tests.refactoring.infra;x-internal:=true,
org.eclipse.jdt.ui.tests.refactoring.nls;x-internal:=true,
org.eclipse.jdt.ui.tests.refactoring.reorg;x-internal:=true,
org.eclipse.jdt.ui.tests.refactoring.type;x-internal:=true,
org.eclipse.jdt.ui.tests.refactoring.typeconstraints;x-internal:=true
Require-Bundle:
org.eclipse.core.filebuffers,
org.eclipse.core.filesystem,
org.eclipse.core.resources,
org.eclipse.core.runtime,
org.eclipse.jdt.core,
org.eclipse.jdt.core.manipulation,
org.eclipse.jdt.ui;bundle-version="[3.8.0,4.0.0)",
org.eclipse.jdt.ui.tests,
org.eclipse.jface.text,
org.eclipse.ltk.core.refactoring,
org.eclipse.ltk.ui.refactoring,
org.eclipse.team.core,
org.eclipse.test.performance,
org.eclipse.ui,
org.eclipse.ui.ide,
org.eclipse.ui.workbench.texteditor,
org.junit;bundle-version="4.8.2"
Bundle-RequiredExecutionEnvironment: J2SE-1.5
and at line 36 "org.eclipse.test.performance" there is a error symbol. hovering over it displays "Bundle 'org.eclipse.test.performance' cannot be resolved"
the manifest from RenameFieldProcessor contains 3 errors.
its content is
Bundle-Name: %pluginName
Bundle-SymbolicName: org.eclipse.jdt.ui; singleton:=true
Bundle-Activator: org.eclipse.jdt.internal.ui.JavaPlugin
Bundle-Vendor: %providerName
Export-Package: org.eclipse.jdt.internal.corext;x-friends:="org.eclipse.jdt.junit",
org.eclipse.jdt.internal.corext.buildpath;x-internal:=true,
org.eclipse.jdt.internal.corext.callhierarchy;x-internal:=true,
org.eclipse.jdt.internal.corext.codemanipulation;x-friends:="org.eclipse.jdt.junit",
org.eclipse.jdt.internal.corext.codemanipulation.tostringgeneration;x-internal:=true,
org.eclipse.jdt.internal.corext.dom;x-internal:=true,
org.eclipse.jdt.internal.corext.dom.fragments;x-internal:=true,
org.eclipse.jdt.internal.corext.fix;x-internal:=true,
org.eclipse.jdt.internal.corext.javadoc;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.base;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.binary;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.changes;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.code;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.code.flow;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.delegates;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.generics;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.nls;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.nls.changes;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.participants;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.rename;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.reorg;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.scripting;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.sef;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.structure;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.structure.constraints;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.surround;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.tagging;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.typeconstraints;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.typeconstraints.types;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.typeconstraints.typesets;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.typeconstraints2;x-internal:=true,
org.eclipse.jdt.internal.corext.refactoring.util;x-internal:=true,
org.eclipse.jdt.internal.corext.template.java;x-internal:=true,
org.eclipse.jdt.internal.corext.util;x-friends:="org.eclipse.jdt.junit",
org.eclipse.jdt.internal.ui;x-friends:="org.eclipse.jdt.junit,org.eclipse.jdt.apt.ui",
org.eclipse.jdt.internal.ui.actions;x-friends:="org.eclipse.jdt.junit",
org.eclipse.jdt.internal.ui.browsing;x-internal:=true,
org.eclipse.jdt.internal.ui.callhierarchy;x-internal:=true,
org.eclipse.jdt.internal.ui.commands;x-internal:=true,
org.eclipse.jdt.internal.ui.compare;x-internal:=true,
org.eclipse.jdt.internal.ui.dialogs;x-friends:="org.eclipse.jdt.apt.ui",
org.eclipse.jdt.internal.ui.dnd;x-internal:=true,
org.eclipse.jdt.internal.ui.filters;x-internal:=true,
org.eclipse.jdt.internal.ui.fix;x-internal:=true,
org.eclipse.jdt.internal.ui.infoviews;x-internal:=true,
org.eclipse.jdt.internal.ui.jarimport;x-internal:=true,
org.eclipse.jdt.internal.ui.jarpackager;x-internal:=true,
org.eclipse.jdt.internal.ui.jarpackagerfat;x-internal:=true,
org.eclipse.jdt.internal.ui.javadocexport;x-internal:=true,
org.eclipse.jdt.internal.ui.javaeditor;x-friends:="org.eclipse.jdt.junit",
org.eclipse.jdt.internal.ui.javaeditor.breadcrumb;x-internal:=true,
org.eclipse.jdt.internal.ui.javaeditor.saveparticipant;x-internal:=true,
org.eclipse.jdt.internal.ui.javaeditor.selectionactions;x-internal:=true,
org.eclipse.jdt.internal.ui.model;x-internal:=true,
org.eclipse.jdt.internal.ui.navigator;x-internal:=true,
org.eclipse.jdt.internal.ui.packageview;x-internal:=true,
org.eclipse.jdt.internal.ui.preferences;x-friends:="org.eclipse.jdt.apt.ui",
org.eclipse.jdt.internal.ui.preferences.cleanup;x-internal:=true,
org.eclipse.jdt.internal.ui.preferences.formatter;x-internal:=true,
org.eclipse.jdt.internal.ui.propertiesfileeditor;x-internal:=true,
org.eclipse.jdt.internal.ui.refactoring;x-internal:=true,
org.eclipse.jdt.internal.ui.refactoring.actions;x-internal:=true,
org.eclipse.jdt.internal.ui.refactoring.binary;x-internal:=true,
org.eclipse.jdt.internal.ui.refactoring.code;x-internal:=true,
org.eclipse.jdt.internal.ui.refactoring.contentassist;x-friends:="org.eclipse.jdt.junit",
org.eclipse.jdt.internal.ui.refactoring.nls;x-internal:=true,
org.eclipse.jdt.internal.ui.refactoring.nls.search;x-internal:=true,
org.eclipse.jdt.internal.ui.refactoring.reorg;x-internal:=true,
org.eclipse.jdt.internal.ui.refactoring.sef;x-internal:=true,
org.eclipse.jdt.internal.ui.search;x-internal:=true,
org.eclipse.jdt.internal.ui.text;x-internal:=true,
org.eclipse.jdt.internal.ui.text.correction;x-internal:=true,
org.eclipse.jdt.internal.ui.text.correction.proposals;x-internal:=true,
org.eclipse.jdt.internal.ui.text.folding;x-internal:=true,
org.eclipse.jdt.internal.ui.text.java;x-internal:=true,
org.eclipse.jdt.internal.ui.text.java.hover;x-internal:=true,
org.eclipse.jdt.internal.ui.text.javadoc;x-internal:=true,
org.eclipse.jdt.internal.ui.text.spelling;x-internal:=true,
org.eclipse.jdt.internal.ui.text.spelling.engine;x-internal:=true,
org.eclipse.jdt.internal.ui.text.template.contentassist;x-internal:=true,
org.eclipse.jdt.internal.ui.text.template.preferences;x-internal:=true,
org.eclipse.jdt.internal.ui.typehierarchy;x-internal:=true,
org.eclipse.jdt.internal.ui.util;x-friends:="org.eclipse.jdt.junit,org.eclipse.jdt.apt.ui",
org.eclipse.jdt.internal.ui.viewsupport;x-friends:="org.eclipse.jdt.junit",
org.eclipse.jdt.internal.ui.wizards;x-friends:="org.eclipse.jdt.junit,org.eclipse.jdt.apt.ui",
org.eclipse.jdt.internal.ui.wizards.buildpaths;x-internal:=true,
org.eclipse.jdt.internal.ui.wizards.buildpaths.newsourcepage;x-internal:=true,
org.eclipse.jdt.internal.ui.wizards.dialogfields;x-friends:="org.eclipse.jdt.apt.ui",
org.eclipse.jdt.internal.ui.workingsets;x-internal:=true,
org.eclipse.jdt.ui,
org.eclipse.jdt.ui.actions,
org.eclipse.jdt.ui.cleanup,
org.eclipse.jdt.ui.dialogs,
org.eclipse.jdt.ui.jarpackager,
org.eclipse.jdt.ui.refactoring,
org.eclipse.jdt.ui.search,
org.eclipse.jdt.ui.text,
org.eclipse.jdt.ui.text.folding,
org.eclipse.jdt.ui.text.java,
org.eclipse.jdt.ui.text.java.correction,
org.eclipse.jdt.ui.text.java.hover,
org.eclipse.jdt.ui.wizards
Require-Bundle:
org.eclipse.help;bundle-version="[3.4.0,4.0.0)",
org.eclipse.core.expressions;bundle-version="[3.4.100,4.0.0)",
org.eclipse.core.filesystem;bundle-version="[1.2.0,2.0.0)",
org.eclipse.core.resources;bundle-version="[3.5.0,4.0.0)",
org.eclipse.core.variables;bundle-version="[3.2.200,4.0.0)",
org.eclipse.jdt.core;bundle-version="[3.8.0,4.0.0)",
org.eclipse.search;bundle-version="[3.7.0,4.0.0)",
org.eclipse.debug.core;bundle-version="[3.5.0,4.0.0)",
org.eclipse.debug.ui;bundle-version="[3.5.0,4.0.0)",
org.eclipse.jdt.launching;bundle-version="[3.6.100,4.0.0)",
org.eclipse.compare;bundle-version="[3.5.0,4.0.0)",
org.eclipse.team.ui;bundle-version="[3.4.100,4.0.0)",
org.eclipse.team.core;bundle-version="[3.4.100,4.0.0)",
org.eclipse.jface.text;bundle-version="[3.8.0,4.0.0)",
org.eclipse.ui;bundle-version="[3.5.0,4.0.0)",
org.eclipse.ui.console;bundle-version="[3.4.0,4.0.0)",
org.eclipse.ui.workbench.texteditor;bundle-version="[3.8.0,4.0.0)",
org.eclipse.ui.ide;bundle-version="[3.5.0,4.0.0)",
org.eclipse.ui.views;bundle-version="[3.3.100,4.0.0)",
org.eclipse.ui.editors;bundle-version="[3.5.0,4.0.0)",
org.eclipse.core.runtime;bundle-version="[3.7.0,4.0.0)",
org.eclipse.ltk.core.refactoring;bundle-version="[3.5.0,4.0.0)",
org.eclipse.ltk.ui.refactoring;bundle-version="[3.5.0,4.0.0)",
org.eclipse.ui.forms;bundle-version="[3.4.0,4.0.0)",
org.eclipse.ui.navigator;bundle-version="[3.3.200,4.0.0)",
org.eclipse.ui.navigator.resources;bundle-version="[3.4.0,4.0.0)",
org.eclipse.jdt.core.manipulation;bundle-version="[1.4.0,2.0.0)",
com.ibm.icu;bundle-version="4.4.2"
Import-Package: org.eclipse.jdt.core,
org.eclipse.jdt.core.dom,
org.eclipse.jdt.core.search,
org.eclipse.text.edits
the error messages are:
Unsatisfied version constraint: 'org.eclipse.jdt.core: [3.8.0,4.0.0)'
Unsatisfied version constraint: 'org.eclipse.jdt.launching: [3.6.100,4.0.0)'
Unsatisfied version constraint: 'org.eclipse.jface.text: [3.8.0,4.0.0)'
Unsatisfied version constraint: 'org.eclipse.ui.workbench.texteditor: [3.8.0,4.0.0)'
dunno how to solve the problem.
Re: Eclipse Classiv vs Eclipse Java [message #873130 is a reply to message #870613] |
Thu, 17 May 2012 10:51  |
Yea, i do not have jdk 1.5 installed. and yes, RenamePrivateFieldTests can still not resolve org.eclipse.test.performance.
edit:
i found the solution with the help of paulweb515. i had to checkout from R3_maintance7 branche instead of master or something else.
[Updated on: Thu, 17 May 2012 12:52] by Moderator
Current Time: Sun Jul 20 22:11:28 EDT 2025
Powered by FUDForum. Page generated in 0.07375 seconds
