Home » Archived » BIRT » client size graph resize(using javascript to resize graph from JSP)
client size graph resize [message #859482] |
Fri, 27 April 2012 13:00  |
I currently am running my graph in a birt viewer within my application on a JSP. I give the user the option to minimize/maximize the chart using an onclick js function. I have figured out how to enlarge the birt viewer/iframe, however, the graph/image remains the same size. Is there any way to enlarge the image as well?
here is my current code that works to enlarge/shrink the birt viewer, but as mentioned before, the graph remains the same size within the viewer:
<birt:report
id="blah"
reportDesign="blahblah.rptdesign"
isHostPage="false"
height="250"
width="444"
format="html">
</birt:report>
<script type="text/javascript">
function chartGrow(){
var x = document.getElementsByTagName("iframe");
x[0].style.height = 500 + "px";
x[0].style.width = 888 + "px";
function chartShrink(){
x[0].style.height = 250+"px";
x[0].style.width = 444+"px";
</script>
Re: client size graph resize [message #865964 is a reply to message #865909] |
Mon, 30 April 2012 13:11   |
Jason,
I have created a method in a java file. in the action class i call that method and build the graph passing in parameters, whch allows me to run it dynamically. it then saves it within my application as a .rptdesign. from there i can call it in the jsp as i mentioned above. here is a cleaned out version of how i am building the graph using the API:
public class ChartBuildAction {
static Logger log = Logger.getLogger(ChartBuildAction.class);
ReportDesignHandle reportDesignHandle = null;
ElementFactory elementFactory = null;
IMetaDataDictionary dict = null;
ComputedColumn cs1, cs2 = null;
public static void main( String[] args ) throws SemanticException, IOException{
String save = "";
String key = "";
new ChartBuildAction( ).createReport(save, key,0,0,0,0,0,0,0);
Platform.shutdown();
log.debug("Finished");
public void createReport(String saveClause, String keyword, int num1, int num2, int num3, int num4, int num5, int num6, int num7) throws SemanticException, IOException
DesignConfig config = new DesignConfig( );
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory = (IDesignEngineFactory) Platform.createFactoryObject( IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
// Create a new report
reportDesignHandle = session.createDesign( );
// Element factory is used to create instances of BIRT elements.
elementFactory = reportDesignHandle.getElementFactory( );
dict = new DesignEngine( null ).getMetaData( );
createDataSources( );
createDataSets(keyword, num1, num2, num3, num4, num5, num6, num7 );
createStyles( );
createBody(keyword );
reportDesignHandle.saveAs( saveClause + "/smallChart.rptdesign" );//$NON-NLS-1$//$NON-NLS-2
private void createStyles( ) throws SemanticException{
StyleHandle labelStyle = elementFactory.newStyle( "Label" );//$NON-NLS-1$
labelStyle.setProperty( StyleHandle.FONT_WEIGHT_PROP,DesignChoiceConstants.FONT_WEIGHT_BOLD );
labelStyle.setProperty( StyleHandle.FONT_FAMILY_PROP, "Arial Black" );//$NON-NLS-1$
labelStyle.setProperty( StyleHandle.COLOR_PROP, "#FFFFFF" );//$NON-NLS-1$
StyleHandle dataStyle = elementFactory.newStyle( "Data" );//$NON-NLS-1$
dataStyle.setProperty( StyleHandle.FONT_WEIGHT_PROP,DesignChoiceConstants.FONT_WEIGHT_BOLD );
dataStyle.setProperty( StyleHandle.FONT_FAMILY_PROP, "Century" );//$NON-NLS-1$
dataStyle.setProperty( StyleHandle.COLOR_PROP, "#009B9B" );//$NON-NLS-1$
reportDesignHandle.getStyles( ).add( labelStyle );
reportDesignHandle.getStyles( ).add( dataStyle );
private void createBody(String keyword ) throws SemanticException
reportDesignHandle.getBody( ).add( createPieChart(keyword ) );
private ExtendedItemHandle createPieChart(String keyword){
ExtendedItemHandle eih = elementFactory.newExtendedItem("tinyChart", "Chart" );//$NON-NLS-1$
try
eih.setName("tinyChart");
eih.setHeight( "240pt" );//$NON-NLS-1$ used to be 235pt
eih.setWidth( "425pt" );//$NON-NLS-1$ used to be 420pt
eih.setProperty( ExtendedItemHandle.DATA_SET_PROP, "Data Set" );//$NON-NLS-1$
PropertyHandle computedSet = eih.getColumnBindings( );
cs1.setExpression( "dataSetRow[\"Name\"]" );//$NON-NLS-1$
computedSet.addItem( cs1 );
cs2.setExpression( "dataSetRow[\"Amount\"]" );//$NON-NLS-1$
computedSet.addItem( cs2 );
catch ( SemanticException e )
e.printStackTrace( );
ChartWithoutAxes cwoaPie = ChartWithoutAxesImpl.create( );
cwoaPie.setType( "Pie Chart" );//$NON-NLS-1$
cwoaPie.setSubType( "Standard Pie Chart" );//$NON-NLS-1$
cwoaPie.setDimension(ChartDimension.TWO_DIMENSIONAL_LITERAL);
cwoaPie.getPlot().getClientArea().getOutline().setVisible(false);
cwoaPie.getTitle( ).setVisible( true );
cwoaPie.getTitle().getLabel().getCaption().getFont().setSize(14);
cwoaPie.getTitle().getLabel().getCaption().setValue("SNAP");
cwoaPie.getBlock( ).setBounds( BoundsImpl.create( 0, 0, 500, 240 ) ); //DO NOT DELETE!!!!!!
cwoaPie.getBlock( ).setBackground( GradientImpl.create( ColorDefinitionImpl.create( 197, 217, 224 ),ColorDefinitionImpl.create( 255,255,255 ),-30,false ) );
cwoaPie.getPlot( ).getClientArea( ).setBackground( ColorDefinitionImpl.TRANSPARENT( ) );
Legend chartLeg = cwoaPie.getLegend();
chartLeg.getClientArea().getOutline().setVisible(false);
chartLeg.setOrientation(Orientation.HORIZONTAL_LITERAL);
chartLeg.getText().getFont().setWordWrap(true);
chartLeg.getText().getFont().setSize(8);
chartLeg.setPosition(Position.BELOW_LITERAL);
if(keyword.contains("MA")){
chartLeg.getInsets().setLeft( -2 );
chartLeg.getInsets().setRight( 10 );
}else{
chartLeg.getInsets().setRight( -2 );
chartLeg.getInsets().setBottom( -2 );
chartLeg.getInsets().setTop(-2);
chartLeg.setBackground( ColorDefinitionImpl.TRANSPARENT( ) );
SampleData sd = DataFactory.eINSTANCE.createSampleData( );
BaseSampleData sdBase = DataFactory.eINSTANCE.createBaseSampleData( );
sdBase.setDataSetRepresentation( "Category-A, Category-B" );//$NON-NLS-1$
sd.getBaseSampleData( ).add( sdBase );
OrthogonalSampleData sdOrthogonal = DataFactory.eINSTANCE.createOrthogonalSampleData( );
sdOrthogonal.setDataSetRepresentation( "4,12" );//$NON-NLS-1$
sdOrthogonal.setSeriesDefinitionIndex( 0 );
sd.getOrthogonalSampleData( ).add( sdOrthogonal );
cwoaPie.setSampleData( sd );
Series seCategory = SeriesImpl.create( );
Query query = QueryImpl.create( "row[\"Name\"]" );//$NON-NLS-1$
seCategory.getDataDefinition( ).add( query );
SeriesDefinition series = SeriesDefinitionImpl.create( );
series.getSeries( ).add( seCategory );
cwoaPie.getSeriesDefinitions( ).add( series );
PieSeries ps = (PieSeries) PieSeriesImpl.create( );
ps.setExplosion(4);
Query query2 = QueryImpl.create( "row[\"Amount\"]" );//$NON-NLS-1$
ps.getDataDefinition( ).add( query2 );
ps.setSliceOutline(ColorDefinitionImpl.BLACK());
cwoaPie.setScript(
"var allnull = true;"+
"function afterDataSetFilled( series, dataSet, icsc ){"+
"if( series.getSeriesIdentifier() == '' ){"+
"var list = dataSet.getValues();"+
"for(i=0;i<list.length;i++){"+
"if( list[i] > 0 && list[i] != null){"+
"allnull = false;"+
"function beforeRendering( gcs, icsc ){"+
"var chart = gcs.getChartModel();"+
"if( allnull ){"+
"chart.getPlot().setVisible(false);"+
"var svheight = chart.getPlot().getBounds().getHeight();"+
"var svwidth = chart.getPlot().getBounds().getWidth();"+
"chart.getPlot().getBounds().setHeight(0);"+
"chart.getPlot().getBounds().setWidth(0);"+
"chart.getTitle().getBounds().setHeight(svheight);"+
"chart.getTitle().getBounds().setWidth(svwidth);"+
"function beforeGeneration( cm, icsc ){"+
"if( allnull ){" +
"cm.getPlot().getOutline().setVisible(true);"+
"cm.getTitle().getLabel().getCaption().setValue('There is No Data to Display');"+
"function beforeDrawDataPointLabel( dph, label, icsc ){"+
"if( label.getCaption().getValue() == '0%' ){"+
"label.setVisible(false);"+
cwoaPie.getTitle().getLabel().getCaption().getFont().setName("Arial");
cwoaPie.getTitle().getLabel().getCaption().setColor(ColorDefinitionImpl.create(6, 55, 95));
cwoaPie.getTitle().getLabel().getCaption().getFont().setWordWrap(true);
ps.getLabel().getCaption().getFont().setSize(9);
ps.getLabel().getCaption().getFont().setBold(true);
ps.getLabel().getCaption().setColor(ColorDefinitionImpl.BLACK());
SeriesDefinition seGroup = SeriesDefinitionImpl.create( );
series.getSeriesDefinitions( ).add( seGroup );
seGroup.getSeries( ).add( ps );
series.getSeriesPalette().getEntries( ).clear( );
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(117,168,250));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(243,239,100));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(255,100,100));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(102,229,142));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(204,243,255));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(249,188,236));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(255,191,0));
DataPointComponent dpc = DataPointComponentImpl.create( DataPointComponentType.PERCENTILE_ORTHOGONAL_VALUE_LITERAL,JavaNumberFormatSpecifierImpl.create( "##%") );//$NON-NLS-1$
ps.getDataPoint( ).getComponents( ).clear( );
ps.getDataPoint( ).getComponents( ).add( dpc );
ps.getLeaderLineAttributes().setVisible(false);
ps.setLabelPosition(Position.INSIDE_LITERAL);
Trigger mouseOver = TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create(150, null)));
ps.getTriggers().add(mouseOver);
try
//Add chart instance to IReportItem
eih.getReportItem( ).setProperty( "chart.instance", cwoaPie );//$NON-NLS-1$
catch ( ExtendedElementException e )
return eih;
private void createDataSources( ) throws SemanticException
ScriptDataSourceHandle dataSourceHandle = elementFactory.newScriptDataSource( "Data Source" );//$NON-NLS-1$
reportDesignHandle.getDataSources( ).add( dataSourceHandle );
private void createDataSets(String keyword, int num1, int num2, int num3, int num4, int num5, int num6, int num7 ) throws SemanticException
if(num1 <= 0){num1 = 0;}
if(num2 <= 0){num2 = 0;}
if(num3 <= 0){num3 = 0;}
if(num4 <= 0){num4 = 0;}
if(num5 <= 0){num5 = 0;}
if(num6 <= 0){num6 = 0;}
if(num7 <= 0){num7 = 0;}
ScriptDataSetHandle dataSetHandle = elementFactory.newScriptDataSet( "Data Set" );//$NON-NLS-1$
dataSetHandle.setDataSource( "Data Source" );//$NON-NLS-1$
int endNum = 0;
endNum = 7;
dataSetHandle.setOpen( "i=0;"//$NON-NLS-1$
+ "sourcedata = new Array( new Array(2), new Array(2), new Array(2), "//$NON-NLS-1$
+ "new Array(2), new Array(2), new Array(2), new Array(2));"//$NON-NLS-1$
+ "sourcedata[0][0] = \"Pending > 90 Days\";"//$NON-NLS-1$
+ "sourcedata[0][1] = "+num1+";"//$NON-NLS-1$
+ "sourcedata[1][0] = \"Pending > 60 Days\";"//$NON-NLS-1$
+ "sourcedata[1][1] = "+num2+";"//$NON-NLS-1$
+ "sourcedata[2][0] = \"Pending > 45 Days\";"//$NON-NLS-1$
+ "sourcedata[2][1] = "+num3+";"//$NON-NLS-1$
+ "sourcedata[3][0] = \"Pending > 30 Days\";"//$NON-NLS-1$
+ "sourcedata[3][1] = "+num4+";"//$NON-NLS-1$
+ "sourcedata[4][0] = \"Pending < 30 Days\";"//$NON-NLS-1$
+ "sourcedata[4][1] = "+num5+";"//$NON-NLS-1$
+ "sourcedata[5][0] = \"Active No Action\";"//$NON-NLS-1$
+ "sourcedata[5][1] = "+num6+";"//$NON-NLS-1$
+ "sourcedata[6][0] = \"Active Needs Action\";"//$NON-NLS-1$
+ "sourcedata[6][1] = "+num7+";" );//$NON-NLS-1$
dataSetHandle.setFetch( "if ( i < "+ endNum +" ){"//$NON-NLS-1$
+ "row[\"Name\"] = sourcedata[i][0];"//$NON-NLS-1$
+ "row[\"Amount\"] = sourcedata[i][1];"//$NON-NLS-1$
+ "i++;"//$NON-NLS-1$
+ "return true;}" + "else return false;" );//$NON-NLS-1$//$NON-NLS-2$
cs1 = StructureFactory.createComputedColumn( );
cs1.setName( "Name" );//$NON-NLS-1$
cs1.setExpression( "row[\"Name\"]" );//$NON-NLS-1$
cs1.setDataType( "string" );//$NON-NLS-1$
cs2 = StructureFactory.createComputedColumn( );
cs2.setName( "Amount" );//$NON-NLS-1$
cs2.setExpression( "row[\"Amount\"]" );//$NON-NLS-1$
cs2.setDataType( "integer" );//$NON-NLS-1$
PropertyHandle computedSet = dataSetHandle.getPropertyHandle(
ScriptDataSetHandle.COMPUTED_COLUMNS_PROP );
reportDesignHandle.getDataSets( ).add( dataSetHandle );
Re: client size graph resize [message #867931 is a reply to message #865964] |
Tue, 01 May 2012 10:57   |
When you create the chart and have the extended item handle just set the
bookmark on it like:
eih.setBookmark("\"MyChart\"");
Jason
On 4/30/2012 1:11 PM, Missing name Mising name wrote:
> Jason,
> IOException{
> String save = "";
> String key = "";
> try{
> } SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
> createStyles( );
> );//$NON-NLS-1$
> );//$NON-NLS-1$
> try
> );//$NON-NLS-1$
> }else{
> ps.setExplosion(4);
> cwoaPie.setScript(
> "allnull = false;"+
> "if( allnull ){"+
> "function beforeGeneration( cm, icsc ){"+ "if( allnull ){" +
> Display');"+
> 55, 95));
> Trigger mouseOver =
> ps.getTriggers().add(mouseOver); try
> return eih;
> int endNum = 0;
> endNum = 7;
> "//$NON-NLS-1$
Re: client size graph resize [message #868373 is a reply to message #868141] |
Tue, 01 May 2012 16:54   |
Jason,
as i mentioned before i am now able to grab both the image and the frame. The frame enlarges perfectly, however i am still having a slight issue with the image...
here is the JS function i am using:
var x = document.getElementById("blah");
x.style.width = 850+"px";
x.style.height = 400+"px";
var graph = document.getElementById("birtGraph");
graph.style.width = 600+"pt";
graph.style.height = "auto";
this function works to enlarge the image, however, it only enlarges the graphics, the bounds of the image still remain the same, so it cuts off. for example the actual image does enlarge, however, the image frame (not the iframe, but the bounds of the actual image itself) stays the same, and the image cuts off halfway through the graph so you only see a portion of it. I believe it is enlargeing the image, but the size of the image is already pre-definied from inside my java class when i use "eih.setHeight()" and "eih.setWidth()". Its hard to describe, but after altering the size, i only see half my image, and the other half is cut off, as if the graphic is too big for the image, so instead of a full pie, im getting a half circle, and my legend is cut off as well.
is there any way that i can alter the eih.setHeight/width size settings using javascript or am i only able to enlarge the actual graphic, but not the image?
thanks,
john
Re: client size graph resize [message #869667 is a reply to message #868141] |
Jason,
thanks,
john
Re: client size graph resize [message #869669 is a reply to message #868373] |
Tue, 01 May 2012 17:50  |
Is the chart type an image or svg. Try png. Look at the attached
example report and run it.
Jason
On 5/1/2012 4:54 PM, Missing name Mising name wrote:
> Jason,
> not the image?
> thanks,
> john
Current Time: Fri Jul 25 18:21:35 EDT 2025
Powered by FUDForum. Page generated in 0.34798 seconds
