Home » Eclipse Projects » GEF » Architecture of Logic example
Architecture of Logic example [message #85534] Thu, 26 June 2003 11:12 Go to next message
Originally posted by: rahul.dhar.intel.com
Going through the code for the logic example, I am wondering why it was
designed this way. There are tons of files (around 90 or 100 I think),
and at least that many classes. Why was it designed this way? Was it for
modularity, extensibility, or just for the sake of example? Since the
application I need to make is very similar (a block diagram editor), I am
wondering whether I should use the logic example as starter code (it seems
like I just need to put in my components instead of the LEDs, etc), or if
I should start from scratch.
-Rahul
Re: Architecture of Logic example [message #85569 is a reply to message #85534] Thu, 26 June 2003 12:51 Go to previous messageGo to next message
"Rahul Dhar" <rahul.dhar@intel.com> wrote in message
news:bdf2hn$j6q$1@rogue.oti.com...
Besides being an example, the logic editor is how we test almost every line
of code in GEF.
It depends on what your end goal is. If you are developing a product, you
should probably take the time to start from scratch and learn each step
involved. Article to follow...
Re: Architecture of Logic example [message #85762 is a reply to message #85569] Fri, 27 June 2003 09:05 Go to previous messageGo to next message
I guess that's my problem then. I'm not sure where to start. What I
really need is something that gives a step-by-step walk through of how to
create a GEF application and tells me why I'm creating/overriding methods
in certain classes. I'm hoping the article you mentioned will at least
get me started in that direction. Do you have an ETA on it?
-Rahul
Re: Architecture of Logic example [message #85775 is a reply to message #85762] Fri, 27 June 2003 09:56 Go to previous messageGo to next message
news:bdhffa$jma$1@rogue.oti.com...
you
Waiting for final critiques and acceptance by "articlemaster"@eclipse.org
Re: Architecture of Logic example [message #85789 is a reply to message #85775] Fri, 27 June 2003 10:50 Go to previous messageGo to next message
Originally posted by: ar9357.sbc.com
When is it expected to be released ?
Randy Hudson wrote:
> \"Rahul Dhar\" <rahul.dhar@intel.com> wrote in message
> you
> > I guess that\'s my problem then. I\'m not sure where to start. What I
> > create a GEF application and tells me why I\'m creating/overriding methods
> > in certain classes. I\'m hoping the article you mentioned will at least
> Waiting for final critiques and acceptance by \"articlemaster\"@eclipse.org
Re: Architecture of Logic example [message #85803 is a reply to message #85775] Fri, 27 June 2003 11:52 Go to previous messageGo to next message
Is it possible to get a sneak preview? I'm assuming that only minor
modifications will be made before it's publically released.
-Rahul
> you
Re: Architecture of Logic example [message #86563 is a reply to message #85803] Sat, 05 July 2003 04:26 Go to previous messageGo to next message
Originally posted by: alex.weirig.telewalfer.lu
Indeed, I would also be interested in this article even if it isn't
the very lastest version ... better having something that still
evolves than not having it.
> -Rahul
>>you
Re: Architecture of Logic example [message #87252 is a reply to message #85569] Tue, 15 July 2003 10:31 Go to previous messageGo to next message
Originally posted by: kgilmer.antennasoftware.com
I'm still getting my feet wet with GEF and am wondering if there has been
any progess on this article...
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bdf89r$p8s$1@rogue.oti.com...
line
> of code in GEF.
for
am
seems
if
Re: Architecture of Logic example [message #87328 is a reply to message #87252] Tue, 15 July 2003 12:00 Go to previous message
IT is being published on the 29th to a website. The link will be added to
the GEF homepage.
"Ken Gilmer" <kgilmer@antennasoftware.com> wrote in message
news:bf139k$ps3$1@eclipse.org...
was
think),
> line
> > of code in GEF.
> for
> am
> seems
> if
you
Previous Topic:Re: CVS Graph plugin for Eclipse available
Next Topic:why no tool change notification in EditDomain
Current Time: Wed Nov 05 06:41:15 EST 2025
Powered by FUDForum. Page generated in 0.06188 seconds
