Home » Modeling » GMF (Graphical Modeling Framework) » Drag'n Drop into diagram
Drag'n Drop into diagram [message #85445] Thu, 14 December 2006 08:44 Go to next message
Hi all,
I would like to implement drag'n drop of a model element from a TreeViewer
to a diagram generated by GMF.
I know how to add a DragListener in the TreeViewer.
But, where should I add a DropListener for the diagram ??
Sylvain
Note that I'm using the last GMF version 2.0M3.
Re: Drag'n Drop into diagram [message #85631 is a reply to message #85445] Thu, 14 December 2006 13:51 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Hi Sylvain,
we did the job of building a generic drag and drop architecure in the
STP BPMN modeler, if you want to look at it.
I think you should add a listener on the DiagramGraphicalViewer when it
is initialized in the editor.
Hope this helps
Antoine
Sylvain Dudoit wrote:
> Hi all,
> TreeViewer to a diagram generated by GMF.
> Sylvain
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website:
http://bpms.intalio.com</a>
Re: Drag'n Drop into diagram [message #85693 is a reply to message #85445] Thu, 14 December 2006 14:04 Go to previous messageGo to next message
Hello Sylvain,
Currently it is possible to D&D nodes from EMF-generated .ecore editor to
the GMF-generated Ecore diagram shortcut to the corresponding element will
be created as a result. You can generate the same code for your domain model
by enabling "shortcutting" functionality across different diagrams of your
domain or you can open EcoreDiagramEditor.initializeGraphicalViewer() to
see how it was implemented.
Alex Shatalin
Re: Drag'n Drop into diagram [message #85984 is a reply to message #85631] Sat, 16 December 2006 19:50 Go to previous messageGo to next message
Originally posted by: carrasco.ModelDrivenDevelopment.co.uk
Thanks for the heads-up on the STP BPMN!
I am just wondering about the ExtendedMetadata annotations :
are these really stating some metainfo that does not fit in ecore ?
or are the values being used to direct some code-gen or runtime contraints ?
Thanks again for the contribution and help,
ACV
"Antoine Toulm
Re: Drag'n Drop into diagram [message #86270 is a reply to message #85984] Mon, 18 December 2006 21:33 Go to previous messageGo to next message
Hi Antonio,
the BPMN modeler is made to do the basic job of representing business
processes.
We plug on the modeler by adding annotations to elements so that we can
interpret them to transform them.
The JWT project would like to go further in this direction. You can find
their proposal on the wiki if you want to know more.
Antoine Toulme
> ACV
> "Antoine Toulmé" <atoulme@intalio.com> wrote in message
> news:els6eb$oh0$2@utils.eclipse.org...
>> Hi Sylvain,
>> I think you should add a listener on the DiagramGraphicalViewer when it is
>> Hope this helps
>> Antoine
>>> Hi all,
>>> Thanks,
>>> Sylvain
Re: Drag'n Drop into diagram [message #87172 is a reply to message #86270] Thu, 21 December 2006 13:59 Go to previous messageGo to next message
Great initiative ! (JWT)
I really look forward to it, and hope it gets provisioned and running soon.
There are quite a few communities that could use such an asset around here,
most notably government and health-care.
I observe that, in order to avoid bias and false starts,
the community needs to watch for formal adoption of
the BPDM (Business Process Definition Metamodel)
now under adoption process in the OMG.
I observe that the Business Process Modelling Notation (BPMN)
, as already standardized and supported by many (notably Intalio, Borland,
etc, ...)
adquires with BPDM a robust metamodel with
syntax and semantics that are both rich and strict enough
to allow Business stakeholders to express themselves
and yet be able to deliver executable process,
without need of any "interpretation".
- no mention of the elgant synthesis between Orchestration (stepping thru
process)
and Choreography (conversations among parties).
Granted, I am biased, as I can
Re: Drag'n Drop into diagram [message #87201 is a reply to message #87172] Thu, 21 December 2006 14:06 Go to previous message
Sorry,
Actually, formal specs as such may be a bit of a dry swim ...
Here
Previous Topic:Can I display the nodes of a diagram in another diagram?
Next Topic:problem with invisible sample editor
Current Time: Fri Jun 20 03:15:50 EDT 2025
Powered by FUDForum. Page generated in 0.28518 seconds
