Home » Modeling » GMF (Graphical Modeling Framework) » How to programmatically resize a structured edit part
How to programmatically resize a structured edit part [message #86120] Mon, 18 December 2006 03:37 Go to next message
Hi all,
depending on some decorations, I want to resize a "structured" edit part - a
UML class with a name label, compartments for properties and methods - by
some code.
To make the class node wider, I tried to call setSize() on nodeFigure and
classFigure level but without effect. Calling setSize() on the label figure
enlarges that one, but I don't manage to trigger a refresh of the parent
figure by calling invalidate() / invalidateTree().
I tried both working on the figures from within the decorator and from a
newly created edit policy.
I already recognized a significant number of resize-related threads here,
but none of them deals with programmatic resize.
Thanks for your help,
Martin
Re: How to programmatically resize a structured edit part [message #86150 is a reply to message #86120] Mon, 18 December 2006 08:12 Go to previous messageGo to next message
Hello Martin,
I think, you should set size on the notation model layer. This means you
have to get Node instance corresponding to the UML class and then call:
- node.getLayoutConstraint() to receive instance of Bounds.
- set size for this Bounds object.
Alex Shatalin
Re: How to programmatically resize a structured edit part [message #86165 is a reply to message #86150] Mon, 18 December 2006 10:21 Go to previous messageGo to next message
Hi Alex,
I recognized that getLayoutConstraint() returns null for my classname
edit part. However, it returns a contraint when called on the
surrounding class edit part.
But setting values on that object (e.g. setSize()) results in an error
saying that I am not allowed to change the resource from outside a write
transaction.
Isn't there another possibility?
Overriding the responsible LayoutMangager is not a suitable approach, I
think.
Martin
Alex Shatalin schrieb:
> Hello Martin,
> Alex Shatalin
Re: How to programmatically resize a structured edit part [message #86180 is a reply to message #86165] Mon, 18 December 2006 11:03 Go to previous message
Hello Martin,
That's correct - you can change a size of surrounding node only (Class Node).
> write transaction.
You can create new AbstractEMFOperation() instance using proper EditingDomain
as a parameter (accessor method is available in GraphicalEditPart), put working
code into implementation of doExecute() method and execute this operation.
Alex Shatalin
Previous Topic:gmf - emf - uml2 version conflict
Next Topic:urgent: the problem with resizing svg figure
Current Time: Thu Nov 06 12:02:06 EST 2025
Powered by FUDForum. Page generated in 0.03722 seconds
