Home » Language IDEs » Java Development Tools (JDT) » attach jdk source didn't work,
attach jdk source didn't work, [message #85998] |
Sun, 17 August 2003 10:22  |
Originally posted by: junk.xsoftware.biz
I tried a few things and I still can't step into the 1.4.2 source. Here
is what I did so far
Window->Preferences, Java->Installed JRE's, clicked on my JRE and clicked
Edit. Added the src.zip to the rt.jar. After this, I verified it worked...
Project -> Properties, then selected Java Build Path, then the Libraries
tab. I then expanded JRE System Library, and then expanded rt.jar and it
showed the source I had attached.
I then tried to verify another way which failed!!!!
From package explorer, I expanded JRE System Library and found the
FileInputStream class and double clicked it. Eclipse told me the source
wasn't found, and luckily had an attach feature. I used that to attach
the source, and all seemed to be attached fine.
I then tried debugging and stepping into FileInputStream constructor and
that did not work.
I read some stuff on the forum about step filtering and decided to reverse
that by doing this....
Window->Preferences, Expand Java->Expand Debug->Select Step Filtering.
Clicked on the Enable All button.
Tried debugging, still can't step into FileInputStream constructor. I
then tried disabling all, tried again and still can't step into the source.
What am I missing? I have been looking around the forums awhile and
didn't see anything else I could be doing wrong. Only saw the stepping
into String and Step filtering posts.
thanks for any help,
dean
Re: attach jdk source didn't work, [message #86029 is a reply to message #85998] |
Sun, 17 August 2003 13:35   |
Here is a little more info. I tried to a library without attaching the
source, and when I step into it, it says that it cannot find the source,
and gives a button where I can attach the source to it and that works!!!!,
but the jdk does not prompt me for it's source for some reason. Something
must be wrong in the step filtering because eclipse must be not even
trying to step into it when I hit the step into button. Any ideas on
this??
> that did not work.
> dean
Re: attach jdk source didn't work, [message #86044 is a reply to message #86029] |
Sun, 17 August 2003 13:40   |
I just thought of something else. possibly jdk1.4.2(sun's) was not
compiled with debugging options on. I somehow got to Thread.exit() and it
says
line: not available [local variables unavailable] when the program was
exiting. It still does not step into LogManager.getLogManager though and
say the source is not available. Anybody successful with using 1.4.2?
thanks,
dean
> this??
worked...
> > that did not work.
> > dean
Re: attach jdk source didn't work, [message #86059 is a reply to message #86044] |
Sun, 17 August 2003 14:07   |
GOT IT. valuable lesson learned. When installing eclipse, it picked the
1.4.2 JRE(which probably doesn't have debugging turned on. Funny thing is
I installed the jdk which installed the jre. You would think eclipse
would pick the jdk and not the jre. It would be nice if eclipse told me
when I attached the source that these jars did not have debug information
and to try the jdk, not the jre. spent hours on this one. Glad to have
it done with.
hope this helps someone else out there and they find this thread,
dean
> says
> thanks,
> dean
> > this??
clicked
> worked...
> > > that did not work.
reverse
source.
> > > dean
Re: attach jdk source didn't work, [message #86990 is a reply to message #86044] |
Wed, 20 August 2003 05:42  |
I think you use a JRE not the JDK.
The jdk does have some debug options but not all.
If you want all run this ant script in the root of the jdk dir (c:\jdk1.4.2)
johan
"Dean Hiller" <junk@xsoftware.biz> wrote in message news:bhoems$cr4$1@eclipse.org...
> says
> thanks,
> dean
> > this??
> worked...
> > > that did not work.
> > > dean
Attachment: build.xml
(Size: 3.20KB, Downloaded 202 times)
Current Time: Wed Sep 03 20:29:31 EDT 2025
Powered by FUDForum. Page generated in 0.07533 seconds
