EMF wizard, UML2 and package name case [message #857313] |
Thu, 26 April 2012 08:53  |
The EMF wizard from RationalRose model converts package names to lowercase in the generated model.ecore. This respects the naming convention of java packages.
The EMF wizard from UML2 (exported from MagicDraw) leaves the package name case.
Can anyone explains why the EMF wizard from UML2 doesn't work like the one from Rose ?
Re: EMF wizard, UML2 and package name case [message #857661 is a reply to message #857594] |
Thu, 26 April 2012 14:53  |
Ed,
Certainly with XML Schema conversion we record the original names from
the schema; they're very important for producing a conforming XML
serialization from the instances. I don't suppose the same concern
arises for UML... Or maybe it does?
On 26/04/2012 7:27 PM, Ed Willink wrote:
> Hi Ed
> It's not Ecore that subjective. The question is about UML names.
> Ecore has a clear Java-like policy.
> UML has its own names.
> There is a strong view that UML names should be preserved.
> There is an equally strong view that once in the Ecore/Java world, UML
> names should be converted.
> Regards
> Ed Willink
> On 26/04/2012 17:42, Ed Merks wrote:
>> Ed,
>> I don't think the case conventions in Ecore are highly subjective.
>> Java has well-defined conventions and EMF follows those so best that
>> converters produce the appropriate convention just as it's best for a
>> generator should generate Java with an appropriate convention.
>> On 26/04/2012 3:23 PM, Ed Willink wrote:
>>> Hi
>>> Whether names should be converted is a highly subjective topic.
>>> The UML genmodel has a variety of PROCESS options for which I think
>>> this behaviour is one.
>>> Use Generator->Show Annotations to see the top level
>>> http://www.eclipse.org/emf/2002/GenModel/importer/org.eclipse.uml2.uml.ecore.importer
>>> annotations in the main editor pane.
>>> Regards
>>> Ed Willink
>>>> package name case.
>>>> the one from Rose ?
FUDForum. Page generated in 0.08761 seconds
