Home » Eclipse Projects » Equinox » proper way to shutdown equinox 3.2 above?
proper way to shutdown equinox 3.2 above? [message #85634] Thu, 29 March 2007 15:47 Go to next message
Could someone explain the proper way to shutdown equinox version 3.2 and
above? I want to make sure all the equinox cache are updated first before
the system is coming down.
I tried to lower the framework start level to 1 (somehow zero is not
working) first by using StartLevel and then calling EclipseStarter.shutdown.
Would this do the trick?
Re: proper way to shutdown equinox 3.2 above? [message #85666 is a reply to message #85634] Fri, 30 March 2007 02:43 Go to previous message
I think that getting Bundle object for the System bundle (id = 0) and
calling stop() will trigger a shutdown of the framework.
Danail
Previous Topic:How to cleanup the equinox cache at startup?
Next Topic:Easy way to capture -debug info
Current Time: Tue Nov 04 21:40:05 EST 2025
Powered by FUDForum. Page generated in 0.10443 seconds
