Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [teneo] unique/required java annotations
[teneo] unique/required java annotations [message #85624] |
Wed, 06 June 2007 11:19  |
Are there annotations for uniqueness and required fields? I am using java
annotations, so I have interfaces like this:
* @model
public interface MyType extends EObject{
* @model
getId();
Then whenever I create a new "MyType", I check to see if one already exists
by using a query. After doing this a bunch of times, I figured there must
be an annotation for this, such as @model unique="true" required="true", or
something like that, but I can't find anything about it.
Paul
Re: [teneo] unique/required java annotations [message #85651 is a reply to message #85624] |
Wed, 06 June 2007 12:56   |
Paul,
Maybe you want @model id="true" to define an EAttribute with isID true,
which will require that the given attribute's value is unique within the
containing resource.
> * @model
> * @model
> getId();
> Paul
Re: [teneo] unique/required java annotations [message #85692 is a reply to message #85651] |
Wed, 06 June 2007 17:25   |
Hi Paul,
Yes, as Ed says, do you mean a primary key? Or just a general uniqueness, required constraint?
Here is an example on how to set required:
@Basic(optional=false)
Here is an example for setting uniqueconstraints using annotations in a xsd:
<xsd:complexType name="Item">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">
@Table(name="MYITEMTABLE"
uniqueConstraints={@UniqueConstraint(columnNames={"MYSTR", "MYINT","MYPROJECT"})})</xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
<xsd:element name="name" type="xsd:string">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Column(name="MYSTR")</xsd:appinfo>
</xsd:annotation>
</xsd:element>
<xsd:element name="project" type="xsd:IDREF" ecore:reference="this:Project" minOccurs="0">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@JoinColumn(name="MYPROJECT")</xsd:appinfo >
</xsd:annotation>
</xsd:element>
<xsd:element name="age" type="xsd:int">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Column(name="MYINT")</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
gr. Martin
Ed Merks wrote:
> Paul,
>> java annotations, so I have interfaces like this:
>> * @model
>> * @model
>> getId();
>> exists by using a query. After doing this a bunch of times, I figured
>> there must be an annotation for this, such as @model unique="true"
>> required="true", or something like that, but I can't find anything
>> about it.
>> Thanks,
>> Paul
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo] unique/required java annotations [message #85783 is a reply to message #85692] |
Thu, 07 June 2007 10:25   |
Thanks for the responses. I think it's working ok now. I misunderstood how
it worked. Now I have the collection (an EList) that holds "MyType"
annotated with @model type="..." unique="true", and I modified the equals
method of MyType to behave the way I want, and now everything is working
great.
"Martin Taal" <mtaal@elver.org> wrote in message
news:f478no$en4$1@build.eclipse.org...
> Hi Paul,
> xsd:
> <xsd:annotation>
> </xsd:annotation>
> <xsd:sequence>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> <xsd:annotation>
> <xsd:appinfo
> </xsd:annotation>
> </xsd:element>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> gr. Martin
> Ed Merks wrote:
>> Paul,
>>> * @model
>>> * @model
>>> getId();
>>> required="true", or something like that, but I can't find anything about
>>> it.
>>> Thanks,
>>> Paul
> The Netherlands
Re: [teneo] unique/required java annotations [message #85811 is a reply to message #85783] |
Thu, 07 June 2007 10:42  |
--------------010107040002090903070009
Paul,
Note that we strongly advise against changing the hashCode and equals
implementation for EObjects. The framework expects that == and .equals
will be equivalent for any EObject implementation, so violating that
assumption is likely to cause problems.
> great.
>> Hi Paul,
>> xsd:
>> <xsd:annotation>
>> </xsd:annotation>
>> <xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> <xsd:annotation>
>> <xsd:appinfo
>> </xsd:annotation>
>> </xsd:element>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> gr. Martin
>> Ed Merks wrote:
>>> Paul,
>>>> * @model
>>>> * @model
>>>> getId();
>>>> it.
>>>> Thanks,
>>>> Paul
>> The Netherlands
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Paul,<br>
<br>
assumption is likely to cause problems.<br>
<br>
<br>
<blockquote cite="mid:f494h2$tma$1@build.eclipse.org" type="cite">
<pre wrap="">Thanks for the responses. I think it's working ok now. I misunderstood how
great.
"Martin Taal" <a class="moz-txt-link-rfc2396E" href="mailto:mtaal@elver.org"><mtaal@elver.org></a> wrote in message
<a class="moz-txt-link-freetext" href="news:f478no$en4$1@build.eclipse.org">news:f478no$en4$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi Paul,
xsd:
<xsd:annotation>
</xsd:annotation>
<xsd:sequence>
<xsd:annotation>
</xsd:annotation>
</xsd:element>
<xsd:annotation>
<xsd:appinfo
source="teneo.jpa">@JoinColumn(name="MYPROJECT")</xsd:appinfo>
</xsd:annotation>
</xsd:element>
<xsd:annotation>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
gr. Martin
Ed Merks wrote:
</pre>
<pre wrap="">Paul,
</pre>
<pre wrap="">Are there annotations for uniqueness and required fields? I am using
* @model
* @model
getId();
it.
Paul
</pre>
</blockquote>
</blockquote>
<pre wrap="">
The Netherlands
Mail: <a class="moz-txt-link-abbreviated" href="mailto:mtaal@springsite.com">mtaal@springsite.com</a> - <a class="moz-txt-link-abbreviated" href="mailto:mtaal@elver.org">mtaal@elver.org</a>
Web: <a class="moz-txt-link-abbreviated" href="http://www.springsite.com">www.springsite.com</a> - <a class="moz-txt-link-abbreviated" href="http://www.elver.org">www.elver.org</a>
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------010107040002090903070009--
Re: [teneo] unique/required java annotations [message #606876 is a reply to message #85624] |
Paul,
> * @model
> * @model
> getId();
> Paul
Re: [teneo] unique/required java annotations [message #606880 is a reply to message #85651] |
Hi Paul,
<xsd:annotation>
</xsd:annotation>
<xsd:sequence>
<xsd:annotation>
</xsd:annotation>
</xsd:element>
<xsd:annotation>
</xsd:annotation>
</xsd:element>
<xsd:annotation>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
gr. Martin
Ed Merks wrote:
> Paul,
>> * @model
>> * @model
>> getId();
>> about it.
>> Thanks,
>> Paul
The Netherlands
Re: [teneo] unique/required java annotations [message #606886 is a reply to message #85692] |
great.
> Hi Paul,
> xsd:
> <xsd:annotation>
> </xsd:annotation>
> <xsd:sequence>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> <xsd:annotation>
> <xsd:appinfo
> </xsd:annotation>
> </xsd:element>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> gr. Martin
> Ed Merks wrote:
>> Paul,
>>> * @model
>>> * @model
>>> getId();
>>> it.
>>> Thanks,
>>> Paul
> The Netherlands
Re: [teneo] unique/required java annotations [message #606888 is a reply to message #85783] |
Paul,
> great.
>> Hi Paul,
>> xsd:
>> <xsd:annotation>
>> </xsd:annotation>
>> <xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> <xsd:annotation>
>> <xsd:appinfo
>> </xsd:annotation>
>> </xsd:element>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> gr. Martin
>> Ed Merks wrote:
>>> Paul,
>>>> * @model
>>>> * @model
>>>> getId();
>>>> it.
>>>> Thanks,
>>>> Paul
>> The Netherlands
<html>
<head>
</head>
Paul,<br>
<br>
<br>
<br>
great.
</pre>
xsd:
<xsd:annotation>
</xsd:annotation>
<xsd:sequence>
<xsd:annotation>
</xsd:annotation>
</xsd:element>
<xsd:annotation>
<xsd:appinfo
</xsd:annotation>
</xsd:element>
<xsd:annotation>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
gr. Martin
Ed Merks wrote:
</pre>
<pre wrap="">Paul,
</pre>
* @model
* @model
getId();
it.
Paul
</pre>
</blockquote>
</blockquote>
<pre wrap="">
The Netherlands
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Current Time: Mon Jul 28 04:46:40 EDT 2025
Powered by FUDForum. Page generated in 0.08565 seconds
