Home » Archived » Test and Performance Tools Platform (TPTP) » Testing Plugin
Testing Plugin [message #85374] Mon, 16 October 2006 18:45 Go to next message
I'm trying to test one of our plugins and asked about automated testing
a while back... it wasnt ready then. I would like to at least be able
to test the plugin running inside the eclipse ide, so I started working
on it again. It seems like it should be able to launch my application
because you can specify the context from a location file (or specify it
from the test suite's overview menu by unchecking the "use current
workbench as context"). However, it wont launch the specified
application, instead bringing up the the eclipse ide, when the record
button is pressed. Do you have any ideas about how I can launch my
plugin instead of eclipse for testing?
Mahesh
Re: Testing Plugin [message #85463 is a reply to message #85374] Tue, 17 October 2006 11:01 Go to previous messageGo to next message
If your plug-in resides in an Eclipse IDE, then you can test it as long as
it is installed under the context being used to playback the test case. The
plug-in can't be tested if it is an RCP application.
Ali Mehregani
"Mahesh Sooriarachchi" <msoori@hotmail.com> wrote in message
news:eh1235$e2h$1@utils.eclipse.org...
> I'm trying to test one of our plugins and asked about automated testing a
> while back... it wasnt ready then. I would like to at least be able to
> test the plugin running inside the eclipse ide, so I started working on it
> again. It seems like it should be able to launch my application because
> you can specify the context from a location file (or specify it from the
> test suite's overview menu by unchecking the "use current workbench as
> context"). However, it wont launch the specified application, instead
> bringing up the the eclipse ide, when the record button is pressed. Do
> you have any ideas about how I can launch my plugin instead of eclipse for
> testing?
> Thanks
> Mahesh
Re: Testing Plugin [message #85491 is a reply to message #85463] Tue, 17 October 2006 19:23 Go to previous messageGo to next message
It is an eclipse application consisting of a bunch of our plugins. I
dont mind running it from inside Eclipse as a plugin instead of as an
application by copying all our plugins into an Eclipse installation.
The problem I have is its not working that way... instead of using my
perspective, it brings up eclipse.
Thanks for your answer
Mahesh
> Ali Mehregani
>> testing?
>> Thanks
>> Mahesh
Re: Testing Plugin [message #85597 is a reply to message #85491] Thu, 19 October 2006 11:01 Go to previous message
As part of recording a test case the user is required to specify a starting
point, which is simply a perspective that will be used to run the test case
in. Are you saying that you're selecting a desired perspective for your
starting point that is not showing up when you launch your test suite in
standard mode?
In standard mode, the test runner launches an Eclipse workbench which will
switch to the starting point (i.e. perspective) of a test case and run the
test case under that environment. I'm confused by your statement: "instead
of using my perspective, it brings up eclipse"
A second Eclipse workbench is always launched in standard mode. The
perspective used really depends on the starting point of the test case that
is contained in the test suite being launched.
Have you had a chance to review the user guide available online?:
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-2-0.html
news:eh3omc$9r0$1@utils.eclipse.org...
> It is an eclipse application consisting of a bunch of our plugins. I dont
> application by copying all our plugins into an Eclipse installation. The
> Mahesh
>> as it is installed under the context being used to playback the test
>> case. The plug-in can't be tested if it is an RCP application.
>> Thanks,
>> Ali Mehregani
>>> Thanks
>>> Mahesh
Previous Topic:Can the probekit change the method param,how to ?
Next Topic:Causes for custom rule not appearing???
Current Time: Wed Sep 03 15:56:57 EDT 2025
Powered by FUDForum. Page generated in 0.26668 seconds
