Home » Eclipse Projects » Equinox » How to cleanup the equinox cache at startup?
How to cleanup the equinox cache at startup? [message #85571] Wed, 28 March 2007 17:44 Go to next message
I have a corrupted org.eclipse.osgi cache directory and when I boot equinox
later I am getting some weird package resolution problem but if I removed
the directory then the problem is gone. However, since I may have bundles
installed in the directory already and I am expecting to start the equinox
with those bundles and from what is in my config.ini so removing the
directory is not an option.
What is the right command line for EclipseStarter to cleanup the cache and
state information but not the bundles? I tried "-initialize" and it helps
but it doesn't already work.
Re: How to cleanup the equinox cache at startup? [message #85590 is a reply to message #85571] Wed, 28 March 2007 20:48 Go to previous messageGo to next message
-clean should do it
"Shean-Guang Chang" <schang@bea.com> wrote in message
news:euenfb$d2e$1@build.eclipse.org...
Re: How to cleanup the equinox cache at startup? [message #85619 is a reply to message #85590] Thu, 29 March 2007 13:28 Go to previous message
I thought "-clean" will remove bundles too.
"Pascal Rapicault" <pascal_rapicault@ca.ibm.com> wrote in message
news:euf2el$j5o$1@build.eclipse.org...
> -clean should do it
equinox
removed
bundles
equinox
and
helps
Previous Topic:Class loader listener
Next Topic:proper way to shutdown equinox 3.2 above?
Current Time: Fri Jul 18 21:59:01 EDT 2025
Powered by FUDForum. Page generated in 0.03267 seconds
