| Newbie question re:/.classpath files [message #85539] |
Mon, 30 June 2003 11:51   |
Eclipse User  |
Originally posted by: murtikins.hotmail.com
I have a number of projects which I would like to start working on with
Eclipse.
I could go and create .project and .classpath for each one, but several
projects are built with the same classpath.
Is there any way of sharing a .classpath file between a number of projects?
It would mean that I wouldn't have to worry about individually updating the
classpath for each project when a new jar was required.
Thanks for any assistance,
Larry.
| Re: Newbie question re:/.classpath files [message #85904 is a reply to message #85539] |
Mon, 30 June 2003 17:12   |
Eclipse User  |
Originally posted by: wegener.cboenospam.com
Larry wrote:
> Eclipse.
> Larry.
If you have a number of common libraries shared across all projects, you
can create a separate project containing just these jar files.  Go to the
Java Build Path->Export tab and select the jar files.  Now go and select
this jar file project as a dependency on your other development projects.
In the future, you just need to add new jar files to the jar project and
make sure that they are exported
FUDForum. Page generated in 0.26065 seconds
