Home » Eclipse Projects » Eclipse Platform » How can I register a paste command handler in PageDesignerEditor?(How can I register a paste command handler in PageDesignerEditor?)
How can I register a paste command handler in PageDesignerEditor? [message #847244] Tue, 17 April 2012 02:02 Go to next message
How can I register a paste command handler in PageDesignerEditor ?
I have successed to do this in ProjectExplorer, but with the same way I can't do this with PageDesignerEditor ?
Is there something wrong ?
Thanks !
<extension point="org.eclipse.ui.handlers">
<handler class="com.my.handlers.PasteHandler"
commandId="org.eclipse.ui.edit.paste">
<activeWhen>
<with
variable="activePartId">
<equals value="org.eclipse.jst.pagedesigner.PageDesignerEditor">
</equals>
</with>
</activeWhen>
</handler>
</extension>
Re: How can I register a paste command handler in PageDesignerEditor? [message #855062 is a reply to message #847244] Tue, 24 April 2012 09:45 Go to previous messageGo to next message
What's the PageDesignEditor? Is it a multi-page editor part?
PW
Re: How can I register a paste command handler in PageDesignerEditor? [message #856976 is a reply to message #855062] Thu, 26 April 2012 02:14 Go to previous messageGo to next message
Paul Webster wrote on Tue, 24 April 2012 09:45
PW
Thanks for help.
PageDesignEditor is a multi-page editor part, it is the HTMLEditor that defined in WPT, and the part id is "org.eclipse.jst.pagedesigner.PageDesignerEditor".
I just want to register a paste command handler in HTMLEditor's GraphicViewer part, not the StyledText part.
If I use the configuration below it works, but it works in other editor too, I don't want to handle ervery editor.
<activeWhen>
<with
variable="selection">
<count value="*" />
</with>
</activeWhen>
Is there any better solution ?
Thanks ~
Re: How can I register a paste command handler in PageDesignerEditor? [message #857355 is a reply to message #856976] Thu, 26 April 2012 09:27 Go to previous message
There's no easy way to declaratively add activate a handler for a page in an MPEP.
You'd either have to write a source provider that looked at the active editor to see if it was an MultiPageEditorPart, find the active inner IEditorPart if available, and post that in a user variable (which could then be used declaratively) *or* programmatically activate/deactivate a handler when the active editor was an MPEP and the inner page is the editor you want.
PW
Previous Topic:How to define a org.eclipse.ui.menus contribution for sub-context-menus
Next Topic:SaveAll Command
Current Time: Sun Jul 27 01:59:12 EDT 2025
Powered by FUDForum. Page generated in 0.05414 seconds
