Best way of running Jubula test cases in continuous integration enviroment [message #854946] |
Tue, 24 April 2012 07:36  |
We're using Jenkins as continuous integration environment, and I would like know the best way of running Jubula test cases on the builds. Probably many people already are doing this, so please advice.
I can start my application with "autrun" and I can run a testsuite with "testexec", but what is the optimal way of running Jubula test cases on the jenkins builds? Should "autrun" and "testexec" be used and how in that case or is there any other easier ways?
I have tried "autrun" followed by "testexec" using "autid", but then the application isn't closed after finished test suite. Closing of the application when the test suite is finished is only done when using "testexec" with a configuration set in Jubula. Is this correct or is there any way to close the application even when testing via "autrun" followed by "testexec" using "autid"?
Regards Richard
FUDForum. Page generated in 0.27057 seconds
