Why the cross-reference does not work? [message #854738] |
Tue, 24 April 2012 03:46  |
Hi, all,
In my simple grammar (see the code below), I want to reference attributes of some entities, e.g., the age of a people. But when I use the grammar, an error occurs as below:
Couldn't resolve reference to Attribute 'age'.
My grammar is below:
Model:
entity += Entity+
expr += Expr*
Entity: 'entity' name=ID '{' attrs+=Attribute* '}';
Attribute: Type name=ID;
Expr: ref=[Attribute];
Type: 'int' | 'string';
and the instance is below:
entity People {
int age
age
What is the problem?
Thanks.
Robin
[Updated on: Tue, 24 April 2012 03:47] by Moderator
Re: Why the cross-reference does not work? [message #854761 is a reply to message #854738] |
Tue, 24 April 2012 04:07   |
From outside the Entity, the age attribute has to be referred to with
the fully qualified name, i.e. 'People.age'. Unfortunately, you specify
the cross-reference as being
[Attribute]
which is equivalent to
[Attribute|ID]
and the ID rule does not allow to the separator char '.'
Am 24.04.12 09:46, schrieb Robin Zhou:
> Hi, all,
> Model:
> entity += Entity+
> expr += Expr*
> entity People {
> int age
> age
Re: Why the cross-reference does not work? [message #854835 is a reply to message #854800] |
Tue, 24 April 2012 05:18  |
I sovled the problem using a format of
Expr: attr=[Attribute|QualifiedAttributeName];
QualifiedAttributeName: ID ('.' ID)*;
The question here is how to replace the '.' by '@' if the last ID is an attribute, so that I can gain the following elments like:
People.Child
People.Child@name
Of couse, I changed the grammar to allow entity nesting.
Thanks.
Robin
FUDForum. Page generated in 0.05073 seconds
