Using DataFilter IN on ActivityInstanceQuery [message #853817] |
Mon, 23 April 2012 07:08  |
We have a requirement wherein we need to find the process OID having a certain activity in hibernated state.
Currently we are following an approach that we first find all process OIDs using getQueryService().getAllProcessInstances(processInstanceQuery). We have applied the required filter criteria for application to this query using processInstanceQuery.where().
We then iterate over all the process instances found as a result of above query to find desired activity in hibernated state. We use following code for the same.
for (ProcessInstance processInstance : instances) {
ActivityInstanceQuery activityInstanceQuery = ActivityInstanceQuery.findInState(state);
long pOid = processInstance.getOID();
activityInstanceQuery.where(PROCESS_INSTANCE_OID.isEqual(pOid)).and(
ActivityFilter.forAnyProcess(activityId));
The customer has performance issue in this flow.
Apparently ActivityInstanceQuery does not change except the process instance OID. Is there any configuration we can use to create prepared statement for such repetitive queries?
Also is it possible to avoid this looping by passing all process instance OIDs in one query inside IN criteria rather than looping through a list and querying database every time. I found DataFilter from Stardust API with IN method but I am not sure I can use it in this case to find activities
Re: Using DataFilter IN on ActivityInstanceQuery [message #854829 is a reply to message #854794] |
Tue, 24 April 2012 05:11  |
As we understand your requirements, it can be achieve with this single query, assuming that you make the third data a descriptor:
public class AiQuery {
ServiceFactory sf = ServiceFactoryLocator.get("motu", "motu");
QueryService qs = sf.getQueryService();
ActivityInstanceQuery aiq = ActivityInstanceQuery
.findInStateHavingData("Hibernation", "HibernatedActivity",
"Data1", "daat1", ActivityInstanceState.Hibernated);
aiq.where(DataFilter.isEqual("Data2", "daat2"));
aiq.setPolicy(DescriptorPolicy.WITH_DESCRIPTORS);
ActivityInstances ais = qs.getAllActivityInstances(aiq);
for (Iterator iterator = ais.iterator(); iterator.hasNext();) {
ActivityInstance ai = (ActivityInstance) iterator.next();
ProcessInstanceDetails piD = (ProcessInstanceDetails) ai.getProcessInstance();
System.out.println("AI: " + ai.getOID() + " PI: " + ai.getProcessInstance().getOID() + " Data3:" + piD.getDescriptorValue("Data3"));
sf.close();
[Updated on: Tue, 24 April 2012 05:12] by Moderator
FUDForum. Page generated in 0.24244 seconds
