Home » Eclipse Projects » GEF » [SOLVED] Problem to show a XML hierarchy of objects using GEF
[SOLVED] Problem to show a XML hierarchy of objects using GEF [message #531580] Wed, 05 May 2010 09:23 Go to next message
Hello
I'm new to GEF and I'm trying to show a hierarchy of objects whose are loaded from a XML file (I put an example of my XML file in the end of the post).
In this hierarchy I have only two kinds of objects (KIND_ONE and KIND_TWO).
I've created a org.eclipse.draw2d.Figure and an org.eclipse.draw2d.EditPart for KIND_ONE and a ...Figure and ...EditPart for KIND_TWO.
The XML is loading ok and the EditParts and Figures are also being created ok.
The KIND_ONE figure is using a BorderLayout as it contains sub-elements.
THE PROBLEM: While "rendering" this hierarchical structure only the elements 10,11,12,13 and 14 (the last ones of the hierarchy) are rendered. But if I use the FlowLayout or the ToolbarLayout all the elements are rendered but not as I would like to show them.
I've spent three days trying many things and reading tutorials and I didn't find any solution.
Any help is apreciated.
Alexandre.
I'm using:
Eclipse 3.4.2
GEF 3.5.1
Classes:
ScrollingGraphicalViewer
ScalableRootEditPart
AbstractGraphicalEditPart
Figure
My XML file:
<XML>
<KIND_ONE ID="1">
    <KIND_ONE ID="2">
        <KIND_ONE ID="3">
        </KIND_ONE>
        <KIND_TWO ID="4"/>
        <KIND_ONE ID="5">
        </KIND_ONE>
        <KIND_TWO ID="6"/>
        <KIND_ONE ID="7">
        </KIND_ONE>
        <KIND_TWO ID="8"/>
    </KIND_ONE>
    </KIND_TWO ID="9">
    <KIND_ONE ID="10">
        <KIND_ONE ID="11">
        </KIND_ONE>
        <KIND_TWO ID="12"/>
    </KIND_ONE>
    <KIND_TWO ID="13"/>
</KIND_ONE>
<KIND_TWO ID="14"/>
</XML>
[Updated on: Fri, 07 May 2010 06:02] by Moderator
Re: Problem to show a XML hierarchy of objects using GEF [message #532134 is a reply to message #531580] Fri, 07 May 2010 05:55 Go to previous messageGo to next message
Ok, problem solved! Very Happy
After a week digging into documentation and tutorials I've found the solution by my self.
The problem was the arrangement of different layouts.
Firstly (when I was having problems) I was just using BorderLayout. After I've reimplemented my project as a generic version and I realized that I was adding all the sub-elements with the constraint BorderLayout.CENTER. Thus, all the sub-elements were put in the center of the Figure (one above the other) and doing this just the last figure of the last added sub-element was apearing on the screen.
SOLUTION: I've combined the use of BorderLayout and ToolbarLayout to get the desired effect I was looking for and now it works.
I'm finishing to implement a generic version of my project as an example of how to combine the different Layouts to get the desired effect and I can send to someone if interested.
Re: Problem to show a XML hierarchy of objects using GEF [message #854516 is a reply to message #532134] Mon, 23 April 2012 22:42 Go to previous message
would you mind send me a copy of your project ,i am troubled in the same question when using GEF.thank you very much .my email:scn19860727@163.com
Previous Topic:To delete an object in gef using the delete key
Next Topic:Force the GraphicalViewer of a GraphicalEditorWithFlyoutPalette to show a specific composite
Current Time: Fri Jul 25 06:13:37 EDT 2025
Powered by FUDForum. Page generated in 0.04878 seconds
