Home » Modeling » TMF (Xtext) » Hyperlinking
Hyperlinking [message #853768] Mon, 23 April 2012 06:05 Go to next message
Hi all,
I'm trying to create an hyperlink from an EObject to another in the same file. I bind the DefaultHyperlinkDetector and then set MyHyperlinkHelper, I override the createHyperlinksByOffset method and in it I add the XtextHyperlink, but can it link to an EObject in the file?
Re: Hyperlinking [message #854140 is a reply to message #853768] Mon, 23 April 2012 13:51 Go to previous messageGo to next message
i do not understand your problem? could you elaborate a bit.
~Christian
Re: Hyperlinking [message #854214 is a reply to message #854140] Mon, 23 April 2012 15:31 Go to previous messageGo to next message
I'm trying to have CTRL click on a VariableName to a VariableDeclaration. I bind the DefaultHyperlinkDetector
public Class<? extends DefaultHyperlinkDetector> bindDefaultHyperlinkDetector() { return MyLinkerService.class; }
this is MyLinkerService:
public class MyLinkerService extends DefaultHyperlinkDetector {
	public IHyperlink[] detectHyperlinks(ITextViewer textViewer,
			IRegion region, boolean canShowMultipleHyperlinks) {
		this.setHelper(new MyHyperlink());
		return super.detectHyperlinks(textViewer, region, canShowMultipleHyperlinks);
in MyLinkerService i set the helper to MyHyperlinkHelper:
public class MyHyperlinkHelper extends HyperlinkHelper {
    public void createHyperlinksByOffset(XtextResource resource, int offset,
    		IHyperlinkAcceptor acceptor) {
    	super.createHyperlinksByOffset(resource, offset, acceptor);
    	TextLocation loc = new TextLocation();
    	EObject eObject = EObjectAtOffsetHelper.resolveElementAt(resource, offset, loc);
    	if (eObject instanceof VariableName) {
    		VariableName varName = (VariableName) eObject;
    		CompositeNode adapter = NodeUtil.getNode(varName);
    		XtextHyperlink hyperlink = new XtextHyperlink();
    		hyperlink.setHyperlinkText("Variable");
    		hyperlink.setHyperlinkRegion(new Region(adapter.getOffset(), adapter.getLength()));
    		acceptor.accept(hyperlink);
XtextHyperlink have a setURI() method but I want a link to the VariableDeclaration in the same file, how can I have this?
Re: Hyperlinking [message #854225 is a reply to message #854214] Mon, 23 April 2012 15:45 Go to previous messageGo to next message
hi,
still do not understand org.eclipse.xtext.ui.editor.hyperlinking.HyperlinkHelper.createHyperlinksTo(XtextResource, Region, EObject, IHyperlinkAcceptor) contains all you need
~Christian
Re: Hyperlinking [message #854229 is a reply to message #854225] Mon, 23 April 2012 15:51 Go to previous messageGo to next message
Btw why dont you simply bind HyperlinkHelper with guice means? your way of extension is not very Xtextish
Re: Hyperlinking [message #854292 is a reply to message #854229] Mon, 23 April 2012 17:20 Go to previous messageGo to next message
I tried to override the createHyperlinksTo but this is never used, i try to put a simple syso in it but nothing happens:
    public void createHyperlinksTo(XtextResource from, Region region, EObject to, IHyperlinkAcceptor acceptor) {
    	System.out.println(HI_TO");
    	super.createHyperlinksTo(from, region, to, acceptor);
I also have tried to bind only the HyperlinkHelper but the method in it aren't used:
public Class<? extends HyperlinkHelper> bindHyperlinkHelper() { return MyHyperlinkHelper.class; }
Re: Hyperlinking [message #854299 is a reply to message #854292] Mon, 23 April 2012 17:33 Go to previous messageGo to next message
the method is of cource only called if YOU call it or you have a real cross ref and thus is called by the framework (in its out of the box config)
besides you missed an important point
	public Class<? extends IHyperlinkHelper> bindIHyperlinkHelper() {
		return MyDslHyperlinkHelper.class;
Re: Hyperlinking [message #854313 is a reply to message #854299] Mon, 23 April 2012 17:49 Go to previous messageGo to next message
I don't have a real cross ref and if I use the IHyperLinkHelper in binding I get this error:
1) A binding to org.eclipse.xtext.ui.editor.hyperlinking.IHyperlinkHelper was already configured at org.eclipse.xtext.service.BindModule.configure(BindModule.java:36).
1 error
com.google.inject.CreationException: Guice creation errors:
Is there a way to create an Hyperlink without a real cross ref?
[Updated on: Mon, 23 April 2012 18:02] by Moderator
Re: Hyperlinking [message #854328 is a reply to message #854313] Mon, 23 April 2012 18:01 Go to previous message
Where do you but your binding I override!!! The existing in the UI
module thus I do not get such strange errors
Previous Topic:Strage Memory leak in Semantic Highlighting
Next Topic:Single File Generation - IFileSystemAccess/JavaIoFileSytemAccess
Current Time: Thu Jul 24 23:59:50 EDT 2025
Powered by FUDForum. Page generated in 0.06786 seconds
