Home » Modeling » TMF (Xtext) » Strage Memory leak in Semantic Highlighting
Strage Memory leak in Semantic Highlighting [message #854055] Mon, 23 April 2012 12:05 Go to next message
We get following strange memory error in out dsl
Has anybody seen this before an can give a hint what could cause this problem
and what todo to solve it?
Christian
!ENTRY org.eclipse.ui 4 0 2012-04-23 17:59:45.187
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.OutOfMemoryError: allocLargeObjectOrArray - Object size: 134217744, Num elements: 33554432
	at org.eclipse.xtext.ui.editor.syntaxcoloring.LightweightPosition.merge(LightweightPosition.java:174)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.MergingHighlightedPositionAcceptor.mergePositions(MergingHighlightedPositionAcceptor.java:122)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.MergingHighlightedPositionAcceptor.mergePositions(MergingHighlightedPositionAcceptor.java:77)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.MergingHighlightedPositionAcceptor.provideHighlightingFor(MergingHighlightedPositionAcceptor.java:52)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.reconcilePositions(HighlightingReconciler.java:87)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.modelChanged(HighlightingReconciler.java:277)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler$1.process(HighlightingReconciler.java:249)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler$1.process(HighlightingReconciler.java:1)
	at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37)
	at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:32)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:78)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.refresh(HighlightingReconciler.java:245)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.install(HighlightingReconciler.java:200)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingHelper.enable(HighlightingHelper.java:82)
	at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingHelper.install(HighlightingHelper.java:71)
	at org.eclipse.xtext.ui.editor.XtextEditor.installHighlightingHelper(XtextEditor.java:491)
	at org.eclipse.xtext.ui.editor.XtextEditor.createPartControl(XtextEditor.java:455)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
	at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
	at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:66)
	at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:474)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1199)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:494)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:480)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
	at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:64)
	at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:226)
	at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
	at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:810)
	at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
	at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:229)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:252)
	at org.eclipse.jdt.internal.ui.navigator.OpenAndExpand.run(OpenAndExpand.java:50)
	at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
	at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:186)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:49)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:867)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:176)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
	at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:463)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1257)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3755)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:129)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:578)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1411)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Re: Strage Memory leak in Semantic Highlighting [message #854088 is a reply to message #854055] Mon, 23 April 2012 12:46 Go to previous message
Hi Christian,
this one never occured for me. Looks like you try to highlight the very
same region completely or partly again and again (probably with the same
style id). This may happen if you have two adjacent regions with some
overlapping on top. There were some recent (4 weeks ago) fixes in
MergingHighlightedPositionAcceptor. You may want to check those out:
http://git.eclipse.org/c/tmf/org.eclipse.xtext.git/commit/?id=c4544291b464f212c982c375f3a2ae6e37820abe
Sebastian
Am 23.04.12 18:05, schrieb Christian Dietrich:
> problem
> Thanks
> Christian
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
Previous Topic:Providing context values for the Xbase interpreter
Next Topic:Hyperlinking
Current Time: Sun Jul 20 21:27:45 EDT 2025
Powered by FUDForum. Page generated in 0.29754 seconds
