Home » Modeling » GMF (Graphical Modeling Framework) » Adding buttons to the elements
Adding buttons to the elements [message #853762] Mon, 23 April 2012 06:00 Go to next message
I want to add a button to some of my elements (the squares/figures of class A.), that when clicked will create a special Node (class B), and will link A to B using an already defined connection between the two.
The idea is :
- click
+- create node
+- create link
and all this will be done automatically.
Can you give me a hint on how to do this?
Thanks in advance
Re: Adding buttons to the elements [message #853807 is a reply to message #853762] Mon, 23 April 2012 06:56 Go to previous messageGo to next message
Hi Eni,
do you want to have a button added to the buttons that appear if you hover over a model element? This is not very hard to realize if you are interested into that.
Ralph
Re: Adding buttons to the elements [message #853880 is a reply to message #853807] Mon, 23 April 2012 08:29 Go to previous messageGo to next message
Hi Ralph,
When I started thinking about the UI side of the project the buttons were going to be visible all the time.
Now that you're telling me the 2nd way is easier, I might as well just make them visible when the mouse hovers for the sake of time, and I will later on try to make them visible the whole time, or just add the same button in the Properties view of the Element.
How can I achieve what you mentioned Ralph? Also, how do I 'automatize' the creation of the other node and the link?
Eni
Re: Adding buttons to the elements [message #853889 is a reply to message #853880] Mon, 23 April 2012 08:37 Go to previous messageGo to next message
can you provide a picture which shows where the buttton shall be visible? Shall it be visible on the selection of the element?
Ralph
Re: Adding buttons to the elements [message #853904 is a reply to message #853889] Mon, 23 April 2012 08:56 Go to previous messageGo to next message
Hello Ralph,
It doesn't really matter,
It can be inside the selection
index.php/fa/8035/0/
Or even outside
index.php/fa/8036/0/
If it's inside, I'd like it to be positioned on the "top-left" corner instead of just the top (like the image).
Anyways, as I said before, as long as it's visible and clickable it's OK Smile
[Updated on: Mon, 23 April 2012 08:57] by Moderator
Re: Adding buttons to the elements [message #853958 is a reply to message #853904] Mon, 23 April 2012 10:04 Go to previous messageGo to next message
For a pop up you need to do the following:
Create a class inherited from PopupBarEditPolicy and overwrite the fillPopupBarDescriptorsMethod:
protected void fillPopupBarDescriptors() {
 super.fillPopupBarDescriptors();
 AbstractPopupBarTool tool = null;
 ImageDescriptor imageDescriptor = null;
 Image image = null;
 tool = new XXXPopupBarTool(getHost(), null);
 imageDescriptor = Activator.imageDescriptorFromPlugin(Activator.PLUGIN_ID, "/icons/tool.gif");
 image = imageDescriptor.createImage();
 addPopupBarDescriptor(null, image, tool, "ToolTip");
Create a class XXXPopupTollBarTool inherited from AbstractPopupBarTool with the followinf methods overriden
public XXXPopupBarTool(EditPart epHost, CreateRequest theRequest) {
 super(epHost, theRequest);
protected Request createTargetRequest() {
 return new RequestForThisTool();
protected Command getCommand() {
 return new CommandForThisTool();
Now you need to install your editpolicy into the editpart
* @generated
protected void createDefaultEditPolicies() {
 //Generated code before...
  removeEditPolicy(EditPolicyRoles.POPUPBAR_ROLE);
  installEditPolicy(EditPolicyRoles.POPUPBAR_ROLE, new YourPopupBarEditPolicy());
That's all.
Ralph
Re: Adding buttons to the elements [message #854882 is a reply to message #853958] Tue, 24 April 2012 06:19 Go to previous messageGo to next message
Hello Ralph,
Thanks for your response.
I still have something unclear though. I'm not sure of how to code the CommandForThisTool and RequestForThisTool classes. I understand they have to extend the Command and Request and I understand I'll have to use CreateRequest for creating the new element and CreateConnectionRequest for creating the new connection between 'this' element and the newly created one. But all this abstractions of GMF make it difficult for me to wrap my head around this whole thing.
Could you please hint me with another code snippet or example?
Edit:
also there's a problem with this line
seems like Eclipse can't recognize the Activator.imageDescriptorFromPlugin(String, String); even though I imported org.eclipse.core.internal.content.Activator; (I tried importing other Activators just in case I wasn't chosing the right one, but the same problem continues).
Edit2:
According to some code I browsed online, should that line be more like this:
imageDescriptor = AbstractUIPlugin.imageDescriptorFromPlugin(Activator.PI_APP, "open.gif");
Eni
[Updated on: Tue, 24 April 2012 09:08] by Moderator
Re: Adding buttons to the elements [message #856082 is a reply to message #854882] Wed, 25 April 2012 06:56 Go to previous message
to implement the tool I do the following:
public IntrospectPopupBarTool(EditPart epHost, CreateRequest theRequest) {
 ChangePropertyValueRequest req = new ChangePropertyValueRequest("XXXX", "XXX");
 return req;
 return new XXXCommand((IGraphicalEditPart)getHost());
I do not use the ChangePropertyValueRequest in my command I just create anyone to implement this abstract method. On getCommand I return my custom command. It is implemented like this:
private IGraphicalEditPart host = null;
 * @param host Element to introspect
public IntrospectCommand(IGraphicalEditPart host){
 this.host = host;
public void execute() {
 super.execute();
 Shell shell = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShell();
 MessageBox m = new MessageBox(shell);
 m.setMessage("Hello World");
 m.open();
You can place whatever code you want in the execute method.
Michael Golubev postest this code a view days ago to create new model element in the way the palette does:
List types = Collections.singletonList(ActivityElementTypes.Action_2001);
CreateUnspecifiedTypeRequest gefRequest = new CreateUnspecifiedTypeRequest(types, PreferencesHint.USE_DEFAULTS);
gefRequest.setLocation(...);
gefRequest.setSize(...);
EditPart containerEP = .... //find EP that should host the new element, DiagramEditPart for top-level elements.
Command gefCommand = containerEP.getCommand(gefRequest);
if (gefCommand.canExecute()) {
   //execute
Ralph
Previous Topic:generating xml-structured file beside the generated xmi file
Next Topic:Exception while generating the code
Current Time: Wed Jul 23 07:29:32 EDT 2025
Powered by FUDForum. Page generated in 0.05306 seconds
