Home » Archived » Sapphire » Could not resolve SapphireActionHandler
Could not resolve SapphireActionHandler [message #853818] Mon, 23 April 2012 07:09 Go to next message
I'm trying to add a custom ActionHandler. I've implemented a class with SapphireActionHandler.
However the sdef file says: "Could not resolve implementation class".
I have imported all packages.
<definition>
     <import>
          <package>de.lmu.ifi.dbs.knowing.core.model</package>
          <package>de.lmu.ifi.dbs.knowing.debug.ui.handler</package>
          <package>de.lmu.ifi.dbs.knowing.debug.ui.editor</package>
     </import>
     <action>
          <id>knowing.dpu.run</id>
          <label>Run</label>
     </action>
     <action-handler>
          <action>knowing.dpu.run</action>
          <id>knowing.dpu.run.handler.default</id>
          <impl>de.lmu.ifi.dbs.knowing.debug.ui.handler.SapphireRunHandler</impl>
     </action-handler>
The class isn't that big yet
package de.lmu.ifi.dbs.knowing.debug.ui.handler;
import org.eclipse.sapphire.ui.SapphireActionHandler;
import org.eclipse.sapphire.ui.SapphireRenderingContext;
public class SapphireRunHandler extends SapphireActionHandler {
	protected Object run(SapphireRenderingContext context) {
		System.out.println("RUN!");
		return null;
Second question. How can I add this action to the section title bar,
where the "hide outline" buttion is located?
thx,
Muki
Re: Could not resolve SapphireActionHandler [message #853837 is a reply to message #853818] Mon, 23 April 2012 07:28 Go to previous messageGo to next message
For the first issue change your impl to just be this:
<impl>SapphireRunHandler</impl>
For the second issue, in your action definition set the Sapphire context to
<context>Sapphire.EditorPage.Outline.Header</context>
Hope this helps!
[Updated on: Mon, 23 April 2012 07:28] by Moderator
Re: Could not resolve SapphireActionHandler [message #853937 is a reply to message #853837] Mon, 23 April 2012 09:39 Go to previous message
Hi Greg,
Thanks for the quick reply. The first question helped me out,
but the context statement doesn't work.
The snippet now looks like this
<action>
  <label>Run</label>
  <image>icons/lrun_obj.gif</image>
</action>
<action-handler>
</action-handler>
However the action is now greyed out ( I added it with an ActionLink to see if it works )
and nothing is shown in the headline.
UPDATE
It was not high enough in the sdef hierarchy. Sorry.
thx in advance,
Muki
[Updated on: Mon, 23 April 2012 09:43] by Moderator
Previous Topic:Diagram node handler factory
Next Topic:Aligning Sapphire 0.5 release with Juno
Current Time: Sat Jul 26 20:41:53 EDT 2025
Powered by FUDForum. Page generated in 0.03462 seconds
