Mac can't open h2 database [message #851308] |
Fri, 20 April 2012 17:33  |
I can't figure out why my mac snow leapord can't open up the default h2 database under .jubula. Here is the client.log
2012-04-20 14:24:00.075 [Worker-2] ERROR o.e.j.c.core.persistence.Persistor - no or wrong username or password
javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: No suitable driver found for jdbc:h2:~/.jubula/database/embedded;MVCC=TRUE;AUTO_SERVER=TRUE;DB_CLOSE_ON_EXIT=FALSE
Error Code: 0
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:517) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:277) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:294) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:272) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.jubula.client.core.persistence.Persistor.buildSessionFactoryWithLoginData(Persistor.java:283) [org.eclipse.jubula.client.core_1.2.0.201203181048.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.<init>(Persistor.java:157) [org.eclipse.jubula.client.core_1.2.0.201203181048.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.instance(Persistor.java:598) [org.eclipse.jubula.client.core_1.2.0.201203181048.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.access$4(Persistor.java:593) [org.eclipse.jubula.client.core_1.2.0.201203181048.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor$2.run(Persistor.java:191) [org.eclipse.jubula.client.core_1.2.0.201203181048.jar:na]
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) [org.eclipse.core.jobs_3.5.101.v20120113-1953.jar:na]
Caused by: org.eclipse.persistence.exceptions.DatabaseException:
Error Code: 0
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:319) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:138) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:584) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:206) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:488) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
... 10 common frames omitted
Caused by: java.sql.SQLException: No suitable driver found for jdbc:h2:~/.jubula/database/embedded;MVCC=TRUE;AUTO_SERVER=TRUE;DB_CLOSE_ON_EXIT=FALSE
at java.sql.DriverManager.getConnection(DriverManager.java:602) ~[na:1.6.0_31]
at java.sql.DriverManager.getConnection(DriverManager.java:154) ~[na:1.6.0_31]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:98) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
... 14 common frames omitted
[Updated on: Fri, 20 April 2012 17:38] by Moderator
Re: Mac can't open h2 database [message #854663 is a reply to message #854033] |
Tue, 24 April 2012 02:14   |
Yes, Jubula does come with H2 drivers. Unfortunately, EclipseLink gives us this error message pretty much regardless of what the problem was with the database creation or connection, which makes analysis difficult.
Could it be a firewall problem? You could try disabling the firewall to see whether it works then.
If you continue to have problems with the H2 database, then I'd recommend setting up an Oracle or Oracle XE database instead. The H2 database is only for demo purposes anyway, not productive use. If you're working with Eclipse for Testers, you'll need to install the database drivers from the Marketplace to do that. If you're working with the standalone, they'll already be there.
Alex
Re: Mac can't open h2 database [message #875976 is a reply to message #854663] |
Wed, 23 May 2012 12:44  |
I can't speak to Jubula per se, but this issue sounds very familiar to me. We've run into it with Virgo applications. There is some real funny business with how H2 is loading the classes for its drivers and that doesn't seem to mesh well with the Eclipse/Equinox class loading mechanism. One thing you can look at is the order of bundle loading.
FUDForum. Page generated in 0.06830 seconds
