Home » Language IDEs » Java Development Tools (JDT) » Eclipse preferences problem(open a search dialog when i select a word using mouse.)
icon4.gif  Eclipse preferences problem [message #827672] Fri, 23 March 2012 12:37 Go to next message
Hi,all!
when I select a word using mouse in the editor area, the search dialog will display under my editor area. I forget what i do with it. It is very upset when i want to copy a line using the mouse, the eclipse alway pop up a warning:
"The operation is unavailable on the current selection. Please select a valid java element."
A screenshot is provided,hope that help to explain my problem visually.
  • Attachment: eclipse.jpg
    (Size: 48.89KB, Downloaded 353 times)
[Updated on: Fri, 23 March 2012 12:38] by Moderator
Re: Eclipse preferences problem [message #830705 is a reply to message #827672] Tue, 27 March 2012 21:18 Go to previous messageGo to next message
Am i the only one running into this problem??
Re: Eclipse preferences problem [message #837681 is a reply to message #830705] Thu, 05 April 2012 20:57 Go to previous messageGo to next message
OMG! no help,no answer!
Re: Eclipse preferences problem [message #841737 is a reply to message #837681] Wed, 11 April 2012 13:25 Go to previous messageGo to next message
You might want to give some context to the problem; you haven't actually asked a question and what you have written reads more like an incomplete bug report. Which version are you using? Where did it come from? What were you doing when this first started? What happens if you close the Search view and reopen the Java Editor?
Re: Eclipse preferences problem [message #853570 is a reply to message #841737] Mon, 23 April 2012 02:15 Go to previous message
Thank you for your reminder, I should have supply the detailed things about my problem.
I have solved my problem in a rude way . I reinstalled my eclipse and there is no question at all. Althought I still believe that the problem I mentioned should be attributed to the setting stuff.
Previous Topic:how does eclipse debug java codes? it uses which jar classes, thx a lot
Next Topic:Information about JDT index format
Current Time: Fri Jul 25 20:00:37 EDT 2025
Powered by FUDForum. Page generated in 0.05633 seconds
