Home » Language IDEs » Java Development Tools (JDT) » Editing library in build path(Editing library in build path)
Editing library in build path [message #853490] Mon, 23 April 2012 00:12 Go to next message
I have developed a library which is being added by the user if he wants to add my custom library for his project.Now add library functionality is working fine but i want capture the edit library event as well.I get some information in my library UI.So when user click on edit library he can see the old values which he has entered earlier. Also i want to capture the remove library event as well so that i can remove my settings from his project if he removes my library from his build path.
Is anybody knows how to do that ?
Thanks in adv.
Re: Editing library in build path [message #853667 is a reply to message #853490] Mon, 23 April 2012 04:14 Go to previous messageGo to next message
Look at org.eclipse.jdt.core.IElementChangedListener. You can listen to changes in model using this.
Re: Editing library in build path [message #853693 is a reply to message #853667] Mon, 23 April 2012 04:48 Go to previous messageGo to next message
Hi Satyam,
Thanks for your reply.
Could you please tell me how can i get remove library event and then add the listener there ?
Re: Editing library in build path [message #853707 is a reply to message #853693] Mon, 23 April 2012 05:04 Go to previous message
Basically you can add a listener to listen to events modifying the build path. Look at http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.jdt.doc.isv%2Fguide%2Fjdt_api_manip.htm under 'Responding to changes in Java elements'.
Previous Topic:Information about JDT index format
Next Topic:The CellEditor can't editor
Current Time: Fri Jul 25 18:20:57 EDT 2025
Powered by FUDForum. Page generated in 0.04567 seconds
