Home » Eclipse Projects » Equinox » Mapping all URLs to one servlet
Mapping all URLs to one servlet [message #85272] Tue, 27 March 2007 01:48 Go to next message
First, many thanks for the work that you're doing on Server-Side
Equinox. It's opening up a whole new world of possibilities for us.
I understand that servlet filters aren't supported by Equinox (bug
#128068), but is it possible via some other means for me to have Equinox
direct *all* URLs to one servlet? I'm trying to use Equinox with the
Restlet API to create some REST web services that depend on Eclipse
plugins and I need to do the equivalent of the following web.xml (from
the Restlet FAQ):
<?xml version="1.0" encoding="ISO-8859-1"?>
<!DOCTYPE web-app PUBLIC
"-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN"
"http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app>
<display-name>Test servlet</display-name>
<context-param>
<param-name>org.restlet.application</param-name>
<param-value>
com.testServlet.TestServletApplication
</param-value>
</context-param>
<!-- Restlet adapter -->
<servlet>
<servlet-name>ServerServlet</servlet-name>
<servlet-class>
com.noelios.restlet.ext.servlet.ServerServlet
</servlet-class>
</servlet>
<!-- Catch all requests -->
<servlet-mapping>
<url-pattern>/*</url-pattern>
</servlet-mapping>
</web-app>
In other words, I want Equinox to map ALL URLs to the ServerServlet
servlet. I wish I could just extend the
org.eclipse.equinox.http.registry.servlets extension point with a
servlet alias of "*", but that doesn't work.
Is there a way for me to work around this issue? Some way to easily
replace the mechanism that Equinox uses to delegate work to servlets,
perhaps?
Thank you!
Jeff
Re: Mapping all URLs to one servlet [message #85345 is a reply to message #85272] Tue, 27 March 2007 07:28 Go to previous messageGo to next message
Jeff
You register the alias of the servlet to be "/". You can do this via the
extension point
<extension point="org.eclipse.equinox.http.registry.servlets">
<servlet alias="/" class="myservlet.Servlet">
</servlet>
</extension>
Richard
> the Restlet FAQ):
> <web-app>
> <context-param>
> <param-value>
> </param-value>
> </context-param>
> <servlet>
> <servlet-class>
> </servlet-class>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> </web-app>
> perhaps?
> Thank you!
> Jeff
Re: Mapping all URLs to one servlet [message #85432 is a reply to message #85345] Tue, 27 March 2007 11:48 Go to previous message
Richard,
That's exactly what I was looking for - thanks!
Jeff
Richard Backhouse wrote:
> Jeff
> extension point
> </servlet>
> </extension>
> Richard
>> Equinox direct *all* URLs to one servlet? I'm trying to use Equinox
>> with the Restlet API to create some REST web services that depend on
>> Eclipse plugins and I need to do the equivalent of the following
>> web.xml (from the Restlet FAQ):
>> <web-app>
>> <context-param>
>> <param-value>
>> </param-value>
>> </context-param>
>> <servlet>
>> <servlet-class>
>> </servlet-class>
>> </servlet>
>> <servlet-mapping>
>> </servlet-mapping>
>> </web-app>
>> perhaps?
>> Thank you!
>> Jeff
Previous Topic:Re: how to get a bundle's root file path?
Next Topic:Monitoring Incubator Bundles and JMX Access Restrictions
Current Time: Mon Oct 20 02:23:59 EDT 2025
Powered by FUDForum. Page generated in 0.04455 seconds
